Maytag 15.6 cu. ft. Upright Freezer MQU1656B Logo
Posted on Apr 18, 2013
Not freezing had it on for about 10 hrs and its not freezing anything
America Refrigeration
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 40 Answers
  • Posted on Nov 15, 2013
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
40
Questions
0
Helped
12548
Points
45
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
How do I fix my icemaker?
if its new it can take up to 48 hrs to produce its first ice cubes, this is due to timer in the ice maker
Why does freezer's alarm sound every 12 hrs?
There could be an ice build up sensor on the coil. try turning it off and using a hair dryer to melt any ice on the coil. This would be inside the rear of the freezer, you would direct the hot air into the vent that the cold air normally comes out of.
Apr 04, 2015 • Freezers
My ge freezer wont freeze
Did you lay it down when you moved?, if so you may have oil in the lines . Did you bump any Freon lines and cause a leak?
Aug 31, 2014 • Freezers
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing point...
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Hello
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 • Freezers
Stopped freezing all the sudden. it remains cold but most items are thawing
switch off your refrigerator for at least 5 hrs. than again switch it on.. if your problem is not solved that it is sure that your thermostart is not working........please replce it
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 • Freezers
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
