Question about Mitsubishi VS-60603 60" Rear Projection Television
Green light on but no picture on CRT TV
The green power light is on, but no picture. The sound seems ok but I can't even get the menu on tv. The lamps are still operational because the pots in the front show a band of each color when tweeked (I know the convergance will need redone.) Any ideas on where to concentrate my components search?
    Sergeant:
  • 254 Answers
Sony wega
1. the lamp may need to be replaced .
2 chk if the door for lamp replacing the lamp is well shot, if not tv will not start.
Jan 21, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light on jvc av32430 is blinking green
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | JVC AV-32430 32" TV
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Hitachi ultravision
It could be you need a new lamp again (your might have gotten a defective one) or "temp" is the temperature sensor that is located on top of you lamp, could be bad also. If the lamp gets too hot, the temperature sensor will shut down you lamp so your TV will not catch on fire. If your temperature sensor has gone bad, your lamp will not turn on at all.
Mar 22, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
