Question about NEC LT265 Multimedia Projector
NEC LT265 Multimedia Projector will turn on, but does not fire up
We have a fairly new bulb in the projector. we can turn it on, but the projector does not fire up. there is absolutely no picture. before this, the picture would quit unexpectedly. it did this for a few days before it wouldn't fire up at all. the light on the projector should just be a solid yellow but it flashes.
    Sergeant:
  • 254 Answers
The bulb needs to be resetted after fixed or the other problem is that the bulb is not fixed.or the ballast is faulty. check out all the options 1 by 1 in the given link how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Mar 11, 2009
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
The lens projector was pushed in and does not turn enough to adjust the focus.
hello therese prof, Hi, the lens is out of alignment, this could be aligned by disassembling the unit up to only on the outer part. of the case. once the cover is removed, you can re align the focus lens. no need to totally dismantle the entire unit. the lens is a separate passive device not connected to the electronics board.
Mar 03, 2011 | NEC LT265 Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
Apr 21, 2010 | NEC VT676 Multimedia Projector
NEC LT265 PROJECTOR WILL POWER UP BUT WILL NOT COME ON. BULB IS A YEAR OLD. WAS PLAYING A MOVIE WHEN IT WENT OFF AND WILL NOT COME BACK ON. NOR WIL THE FAN RUN. POSSIBLE BALLAST?
It cannot be a ballast because the fan would not run off a ballast. Sounds like a serious hardware failure, I would check with the manufacturer.
Mar 10, 2010 | NEC LT265 Multimedia Projector
I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Nov 13, 2009 | NEC VT700 Projector
Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Mar 23, 2009 | NEC VT676 Multimedia Projector
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
NEC LT265 Multimedia Projector Logo
675 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
