Question about Garden
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
My son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Posted on Jul 06, 2009
  • 4 Answers
If it has been setting very long with gas it probably has the carb clogged. first try to clean or replace the fuel line pick up filter in the tank.
Posted on Mar 11, 2009
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Saw would not start so I bought a new carb and it still won't start. Fresh gas, new plug, etc. How do I determine if I am getting spark to the plug and is it difficult to check the magneto or device that...
I would suggest finding an inline checker so you can visualize the spark without getting shocked for damaging the plug boot.
If your carb is working then when you take out your spark plug it should be covered with fuel. This could be a sign of no spark or it might be a sign of a dirty air filter causing an extreme rich condition. Try starting the saw with a clean plug and no air filter in place to rule this out. If it is dry you either have a fuel line issue or a blocked exhaust. Chain saws have spark arresting screens on them that can load up with unburnt fuel and oil *(from a bad carb or blocked air filter) be safe and good luck!
Mar 07, 2015 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Stihl weedeater stalls when I compress throttle trigger
dump the fuel --clean air filter-change spark plug-- use new fuel synthetic 2 cycle oil--93 octane
Oct 11, 2014 | Stihl Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
When i give my stihl weedeater (fs 55) gas it dies. i changed the gaskets in the carburetor, new spark plug, new air filter. it idles fine just when i give it throttle it dies
This could be from a bad fuel filter (has a dark appearance when dry), from the spark arrestor screen in the muffler being plugged up with carbon deposits (take out the spark arrestor screen and clean it by burning off the carbon deposits), or the carburetor needs to be adjusted. If the carburetor needs to be adjusted I would take it to the nearest Stihl dealer that has a Gold Certified Technician. That way the unit is adjusted properly and is in good running condition. You can find a local dealer with the dealer locator. The link is HERE.
Mar 19, 2011 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Garden Logo
3,053 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
