Question about Home Security
My sentinel cctv when powered on all the indicator lights flash on and off and there is a clicking sound. Any idea what the problem is?
  • 4 more comments
  • Anonymous Mar 21, 2009
    When power is turned on,led lights and power light blink rapidly,accompanied by a rapid clicking.Nothing comes up on screen.Nor do any of the control buttons have an effect.
  • searchman2 Mar 31, 2009
    I have a similar problem. I cannot use any of the controls including the on and off switch. I can pull the plug and plug it back in and the same clicking sound occurs and also the green led next to the hard drive light flickers.
  • tjmfed Apr 14, 2009
    same just clicks lights flicker no help from company
  • Mike Jardin Apr 28, 2009
    I have this issue too. I know that it is a power supply issue because checking the voltages at the disk drive power connector yields strange out of spec voltages... not even close to 5V & 12V.
    The bad power will often take out the drive. I have to trace the circuit upstream to see where it is going bad. Please let me know if you guys pinpoint the failing component before I do. Mike
  • SUNRISEPMP Apr 29, 2009
    I had the same problem, I bought my unit in 2006 from Costco I could not find the reciept nor did i have the box but i called Costco and told them that the manufacture was no help They told me to bring it to them They gave me 100% refund and i purchaced the model Lorex L19WD Series very nice unit.Good luck to all. YOU ROCK COSTCO
  • Anonymous May 10, 2009
    I have same problems too. see anyone can help us out>> thank
  • 3 Answers
Hello sunrisepmp, i bought the model lorex l19wd and i have some problems with the remote connection. i can`t view my cameras remotely...
Locally everything work perfect but when i try to establish a remote connection, the lorex client 7.0 tell me that the connection is sucessfully but i can`t see any image.
I`ve a linksys wrt54G router and a speedstreem 4200 modem, i connect the system directly to the modem, also i create an DDNS Account (i had a doubt about the mac adress that you have to put at the form, i filled with the mac of the system) and i configured the system with the information that you sent me to my email, like the manual said...
Thank You
Posted on Jul 29, 2009
I have just bought swann cctv cameras for my home And on the recorder the blue light is flashing is this normal ??
I too own a Swann security system. The flashing light indicates that one or more of your cameras has sensed movement and is recording images onto the hard drive. This is 100% normal and means everything is working. Use the mouse that came with your system and click on the house icon, this is where you tweak your system to do what you want. I've had mine for 5 years and with the exception of some camera failures it works great!
Jan 16, 2018 | SWANN Home Security
1998 Oldsmobile Aurora Lighting problem-car parked,ignition off,doors locked,unattended,weather normal.parking lights will come on and stay on,by themselves,other times they come and flicker and turn...
sounds like there is a short somewhere. you need to start checking things with a multi meter, could be a bad switch. I would recommend picking up a factory service manual for your vehicle off of ebay. If you need any further assistance let me know.
Thanks,
lee
Aug 02, 2008 | Oldsmobile Aurora Cars & Trucks
Plug in and red light flashes and makes a click sound
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | JVC AV-32850 TV
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is...
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Apr 08, 2011 | Omron Healthcare Omron H3cr-a-ac100-240v...
My Sentinel CCTV monitor will not come on. It
It seems that something is wrong with the dvr. Maybe transport damage. You need to get it checked by a professional.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 05, 2010 | Home Security
Sentinel 21'' Security CCTV Clicks when powers on
replace the capacitor when they bulg they will make a clicking sound and make the lights flash on and off as for the visible damage to the hard drive we will cross our fingers.
Jul 29, 2009 | Home Security
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Home Security Logo
1,285 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
