Question about Dell Inspiron Notebook
Keys 1 and 5 will not register on my laptop dell 1nspirion 1525
The 1 and 5 will not work and now i can't down load my norton defence because these two number are part of the activation cde i have no firewall or anything else for that matter can you help ?//
    Sergeant:
  • 239 Answers
Try using a desktop keyboard
Posted on Mar 20, 2009
My daughters 1525 dell laptop will not work properly.You can turn it on the dell name appears and that is it all lights are working fan is working I hope you can help with out me she has all her photo;s...
If the power LED is ON and you can sense the fan as well problem might be on the LCD or Motherboard.
Could you please try this one and give me feedback what had happened.
Remove ac adapter and battery from laptop.
Press and hold down power button on the laptop for 10 seconds.
Plug in the ac adapter.
Hold down the Fn key then press power button once, then just keep holding down the Fn key.
You might not see anything on the screen but please do take note of the error code or beep codes.
Thanks!
Apr 29, 2011 | Dell Inspiron 1525 Notebook
Where is hash button on dell 1525 keyboard?
Hold down both the Shift and 3 keys at the same time. That's the usual combination for QWERTY keyboards.
Feb 23, 2011 | Dell Inspiron 1525 Laptop
How do I darken my computer on the Dell Inspiron 1525
Hold the "FUNCTION" key down and tap the LEFT ARROW key to darken, tap RIGHT ARROW key to lighten the screen.
Good Luck
Jan 06, 2011 | Dell Inspiron 1525 Laptop Computer PC...
My dell inspiron 1525 notebook brightness is goes down,it looks very dark, whatshould i do?????
Press the Fn key and the up arrow key simultaneiously, this should increase the brightness. (down arrow key reduces the brightness)
If this does not increase or decrease the brightness, then the problem should be with the backlight or the backlight circuits. Please contact Dell for a replacement of the LCD panel (if your computer is in warranty) if not contact a local tech who can replace the LCD panel or the Backlight for your laptop
Dec 25, 2010 | Dell Inspiron 1525 Notebook
I have dell insprion 1525 laptop. my dvd drive does not read dvds, the green light just continuously blinking. cds shows blank.
Hi
Please can you try the following
1) Power in laptop
2) Continuously press the F8 key until a advanced startup menu is seen
3) Choose safe mdoe
4) Try CD in safe mode and see if it works
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
How do i get my enter button back on my inspiron 1525?
The keys just pop on and off. If the key will not snap back on, then the keyboard will most likely need replacement.
Replacement keyboards are less than $20
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=dell+inspiron+1525+keyboard&_sacat=See-All-Categories
Oct 23, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Dell 1525 installed updates, computer re-booted on 3rd update says installing update but it will not and computer shuts down and restarts and continues doing the same.
1. Turn off the computer.
2. Turn on your computer and start pressing the F8 key on your keyboard.
3. Select last known Good Configuration from boot Menu and press enter
4. This option should work but if it does not work try Safe mode option
Jun 23, 2009 | Dell Inspiron 1525 Notebook
I have dell inspiron 1525 and it is not working properly i was surfing the net and suddenly my laptop stopped working and shut down I turned it on again and all my drivers are not working properly my...
when u power up the computer press F8 key then enter in last know good configuration .
Then go to start menu and type in run "chkdsk /r"
then press "y"
then restart the computer then wait till disk checking completed then it auto restart and then winxp loads.
Tehn check all are working good or not.
Please let me know.
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron Notebook Logo
Alun Cox
