Question about LG DLEX0001TM Dryer
Dryer light comes on but unit will not power up or turn on
When we open the door to our dryer the light comes on, but the dryer will not turn on. We have checked for any buttons that might be sticking and can't find anything. We also have checked to make sure that the power button isn't stuck. Has anyone experienced this type of issue?
  • 2 more comments
  • swetepy14 Mar 11, 2009
    We have it plugged into a 240v 3 prong 30 amp circuit.
  • swetepy14 Mar 12, 2009
    We checked and reset breaker with no luck.
  • swetepy14 Mar 13, 2009
    We checked and the light comes on when we open the door and goes off when we shut it. We also pushed the switch and the light comes on and goes off. The switch and the door are making contact. AC plug is okay.
  • Mark Van Skiver May 11, 2010
    Voltage please?
    Scholar:
  • 124 Answers
Check & reset breaker in breaker box.
Your problem may be you have lost one side of your voltage coming in. Light in dryer comes on but circuit to start motor is off.
Msg back if that does not work& we will go further.
Posted on Mar 11, 2009
  • 1 more comment
  • Mark Van Skiver Mar 12, 2009
    Wow sorry took so long to get back to you email provider slow today.
    Ready here we go.
    1. You say little light comes on. But does little light go out? Check by using your finger or the handle of your tooth brush to push switch see if light goes dark.
    2. Light went out. ouch more work. is the door staying closed & is the switch making contact with door? seems ok keep going.
    3. Check make sure main ac plug is not cracked & is securely plugged in.
    4. Comment me back & will go from there be warned your approaching more serious troubleshooting.
  • Mark Van Skiver Mar 13, 2009
    OK this is very dangerous even unplugged you have capacitors that store voltage /amps that can hurt or kill you. I do not recommend you go any further unless you are comfortable with a voltage meter.
    Check Plug make sure you have.
    220 across main legs & 110 across each one main leg to ground/neutral.
    If you do it is not house wire.
    In the back of dryer remove top back panel look for lose or burnt electrical lines.
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
The dryer won't turn on when plugged in. However, when I open the door, the drum light turns on.
I have the same dryer and the same problem...I have power to the unit but it wont turn on....the light in the door is on....there is a small cllick to the top left when I try and start it..thats it..!!...did you get a solution yet?..thanks..mike
May 15, 2011 | LG DLGX7188 Gas Dryer
The light inside the dryer comes on when the door is open so I know I am getting power to the unit but nothing happens at all when I try to start the dryer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2010 | Fisher and Paykel DG06 Gas Dryer
I have the kenmore400 dryer it will not turn on & no light inside
not getting power to unit check the breaker panel. if you have a volt meter check the outlet for power.
Sep 02, 2009 | Kenmore Dryers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
LG DLEX0001TM Dryer Logo
320 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
