Question about Hayward Phantom Robot Cleaner without Booster Pump
Cleaner wont go . I cleaned the filter. and checked the cleaner for cloug .every thing seems ok.It wont go
    Problem Solver:
  • 10 Answers
Whith the main pool pump on and the booster pump on too. pull the hose up to the deck, without pulling the phantom out of the water. You will see unions leaking, you will have to replace them. what is happening is pressure is being relieved from the unions and their for, does not have the force to move the phantom..
Posted on Mar 11, 2009
I've got a little southland tiller and the thing
Remove the air cleaner and spray carb cleaner into the throat of the carb then try to start. If it starts right up for a second then its a fuel problem and the carb will need to be rebuilt, also check the fuel lines and filter. If it wont run for a second on the prime then you have an ignition or compression problem.
Sep 24, 2012 | Garden
My 2001 Malibu seems to have a throttle problem. It sticks at 1500 rpm when at a stop light and will hold at 42 mph when in motion. I had a fuel cleaning service done, tune up, intake gasket, fuel...
are you spraying it in the intake at the throttle valve.if so then you need to clean the throttle valve thoroughly front and back.have you checked the throttle cable for rough spots in it.its more likely its just a dirty throttle valve.
May 22, 2011 | 2001 Chevrolet Malibu
When my vehicle is running and I stop at the light or if i'm parked with the vehicle running, the engine seems like its about to shut off. what oculd this be?
About 12 things
Clean the Throttle Body with --CRC Throttle Body Cleaner
Clean MAF Sensor with -CRC MAF Cleaner
Need a fairly clean Air Filter
No Vacuum Leaks --anywhere ( including ducting-- filter to throttle)
Common sense--Spark Plugs,every three years,not more than 50,000 miles
--Gas Filter,every three years,30,000 miles
Check --for loose O2 Sensors (Vacuum Leaks)
Check--TPS Sensor,at idle
Oct 08, 2010 | 2002 Ford Explorer
The machine has suddenly stopped cleaning properly. I put a cleaner through every few weeks and the inside is clean. I have blown through the pipes and they seem to be ok. I have removed the arms and...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 20, 2010 | Neff 24 in. S4443 Built-in Dishwasher
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
Car died out, there is gas in the car, fuel pump is ok, seems that gas is not being deliverd.when the car does start and you rev the gas it seem to bog down.
Get the fuel filter and fuel injector cleaned.
And also let me know what excatly problem when try to start the car.
Let me know
Thank
Kevin
May 11, 2009 | 1996 Chevrolet Cavalier
The chevy impala 2000 car wont stay running just stalls out
U can also clean the INSIDE of the MAF sensor, use MAF spray cleaner, (made by CRC chemicals) it is avail. from most parts stores for arouind $5, check the fuel pressure after u change the filter and while u are at the parts store ask if they can run your system computer for trouble codes, it is free if u go to Kragen or Autozone.
Jan 13, 2009 | 2000 Chevrolet Impala
Toshiba equium laptop
it seems to be some dirty thing on lens so you may buy  a dvd cleaner then clean the lens and you need to clean your disk drive every 15days intervar ok
Jan 21, 2008 | Toshiba Satellite A60 Notebook
Hayward Phantom Robot Cleaner without Booster Pump Logo
241 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
