Question about Kenmore Elite HE4 Electric Dryer
Frontload Washer: F02 Error
We are having the same F02 error and have checked the filter, the pump impeller, and all of the hoses for clogs. There was nothing present, but when the wash cycle enters its final spin you can hear the pump motor making a lot of noise, and then periodically we get the error. The only thing I have not checked is drain line from the bottom of the wash basin to the drain pump.
You mention that there is a ball-valve at the top of this line, and that there are sometimes garments or obstructions in here that could cause these draining problems, but how do you access that area? I did not want to disconnect a hose that I would not be able to re-connect. If I need to check this black rubber hose, what is the best way to check this hose and the ball-valve at the top without damaging anything?
    Problem Solver:
  • 11 Answers
I had the same problem i watched the repairman take the pump appart and pull out a sock and a pencil and screws a bunch a little junk and it still running fine two almost three years later
Posted on Apr 20, 2009
Kenmore Elite, HE3t, front loading washer, Model 110.45972404. Constantly shuts down during cycle with SUD or F02 signals. If I pause and restart sometimes it works. However last night it would not drain...
F02 indicates the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
I think the drain pump is clogged due to SUD formation.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Jul 08, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
F02 Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
If the pump motor or impeller becomes damaged and does not pump at the correct volume, the error code will not clear. If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Washing Machines
I followed the tips for the f02 code, cleaned hoses and filter and it didnt fix it. ordered a new pump online and it came in with one of the four impellers broken leaving only 3. I installed it ran spin...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@#@#@#
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error Pump Filter hoses all ok. Whirlpool duet front load.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 06, 2010 | Kenmore HE3T Washer
Our Kenmore HE4T frontload washer is displaying an F02 troubleshooting code. What does that mean?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
F02 whirlpool washer
HI, check the descriptions below to address this issue.
F02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 08, 2009 | Whirlpool Washing Machines
My kenmore elite he3t showed an error code f02, i unpluged it and plugged in back in i tried to run a drain/ spin and the machine make a strange noise i suspect the motor filter is clogged and the moter is...
Potential Causes
***You stated that there was a noise when you started a manual drain. This may be a damaged drain impeller. in this case, replace the entire pump(drain).
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Frontloader Washer: F02 error
F/02 :-------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
to resolve the problem ------------
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 error on Kenmore front load, followed solution, problem still exist, What next?
cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
