Question about Canon PIXMA MP150 All-In-One InkJet Printer
Keeps giving me E2 not printing a paper will com e through when
Keeps givin me E2
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
If you hear the printer trying to grab the paper (you also may see that the rollers turn) but it does not grab the paper , means the the rubber that grabs the paper are dried, and should be replaced.
If the rollers do not turn (no sound either) then there is a problem with printer's mainboard.
Meanwhile (if you need it urgently) put more pages in tray to add volume (will press the paper to the rubber).
Posted on Mar 11, 2009
    Sergeant:
  • 254 Answers
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
My Canon PIXMA flashes Error 2 and Error 3 after I print several docs. After that it wont print again...when I lift the scanner to check what happened the ink cartridges wont move(like in replacing...
E2 error => paper jam (no paper)
E3 error => paper jam (take out the jammed paper)
I would reset your printer if this keep comming out.
1.Switch the Printer ON by pressing the Power Button (Make Sure Paper is not Loaded)
2.Once switched on, hold down the Power Button (DO NOT RELEASE)
3. Now press the Cancel Button and let go of it
4. Now Release the Power Button
5. Wait...
6.The INK LED will light up,
7. After a while it will attempt to print a sheet but because there is no paper the resume button will blink
Now press cancel
You have completed the steps and now should be able to print if not attempt this again from STEPS 1-7
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
http://www.youtube.com/watch?v=tZlkJ-YDsZA
May 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Im trying to print my airline tickets and the printer is flashing E2 dont know what that is but i can not print what do i need to do?
Pressing the Black button could clear the alarm.
If not, your could try to reload your paper.
E2 alarm is when ther is no paper or paper not correctly loaded.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hello all, I have MP 140 printer too, but it does not work. Some days ago the printer gives E2-2 error code (the device is filled with paper). I have tried to swich off and on the machine, but it does not...
his particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Jan 20, 2011 | Canon MP140 PHOTO AIO All-In-One InkJet...
Whenever I try to print a page, error E2 appears, even reinstalling does'nt solve the problemm
E2, Error Code [1000] or Alarm LED blinking in 2 times is mean No Paper in Auto Sheet Feeder. Insert paper in ASF and press OK button.
May 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer pixma mp 150 - keep getting error e 2 when i try to print
Sir,
when your printer is not recognized paper or paper tray is blank.Then it show E2.Paper tray switch is not on or switch is not work.Please clean it soft brush.Reload the paper correctly and press black or color.
Jan 09, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
