Question about Refrigerators
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
I have a Kenmore 5126101 side by side refrigerator. The middle separator between the fridge and the freezer is extremely hot. The temperature in the fridge is within range and all foods in the freezer are still frozen.
  • 410 Answers
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Mar 11, 2009
It was the cooling motors fan blade, the material on the bottom of the refrigerator was pushed, wedged up against the blade, preventing it from turning, when freed up, it started operating. the middle separator is now cool and the freezer is operating, must have happened when we moved it with the dolly. thanks again
Posted on Apr 13, 2009
  • hchristmas Nov 15, 2010
    The fan is moving, but it is not cooling. Any ideas?
Squeaky, chirping sound & exterior of fridge on veritical middle panel and freezer side are hot
I think you should try the following:
1. turn off the power.
2. clean/vacuum the lint under and behind the fridge.
3. after a few hours, power on.
If this does not work, you will have to call a repairer unless it is under warranty.
good luck
Mar 15, 2014 | LG LSC26905TT Side by Side Refrigerator
Two door side by side fridge middle wall is hot ,fridge not working very well ,5 year old kenmore ,any soloution ?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Kenmore 53642 / 53644 Side by Side...
After relocating refrigerator, no cooling, middle panel very hot
Hwne you had moved the fridge it is quite possible that there could have been a damge to the compressor or the piping resulting in the gas leaking off. This must be confirmed , if so refill gas properly with the help of a technician. Next solution also could be if the fridge had been been transported upside down or side ways. If so the oil inthe compressor would have gone into the system and choked it. For a trial put off the fridge for about 24 hours so that all the oil drains back to base. then test it to check if the cooling comes back. Since I presume prior to your moving the fridge was working fine, the areas of fault could be these two factors. I hope you can check this up and decide . If not ask for a quote on the fault and we can review. I Hope I could help. Good day
Jul 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator is cold inside, but bar in the middle separating the frezzer from the fridge is hot to the touch
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. Ihad inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Aug 25, 2009 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Refrigerators Logo
571 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
