Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer making loud squeaking sound
Our dryer is making a loud squeaking sound a minute or two after being turned on.
  • 221 Answers
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Posted on Mar 11, 2009
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My dryer is making a
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
  • 5 Answers
SOURCE: Dryer drum doesn't turn; makes a loud squeak sound
The problem is most likely your drum belt. Most run all the way around the outside of the drum, across a tensioner pulley, and around the motor.
This could be easy, or it could be a nightmare. Disassembly of the outer cabinet can be tricky. Some drums ride on pullies, while others slide on drum felts.
Your local appliance parts store can give you some guidance, and probably a few cards of qualified service guys. If you're mechanically inclined, and have a history of being able to take machines apart, AND reassemble without extra parts laying around, then give it a shoy. Otherwise, pay a pro, and save your Saturday.
Posted on Jun 25, 2008
heatman101
  • 43501 Answers
SOURCE: Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Posted on Sep 29, 2010
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer is not working makes loud noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
There is a squeaking sound when running the dryer
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Nov 28, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
732 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
