Question about Nikon Coolpix 4800 Digital Camera
The camera is developing dark areas around the edge of the pictures on 2 different sides. you can see these dark spots on the viewfinder and on the pictures. what is causing this?
I have had this identical camera for many years. Sometimes the lens cover doesn't open completely, and if I don't notice it, the photo will have dark edges. Could this be your problem?
Posted on Aug 18, 2009
  • 124 Answers
If your lens is clean.
The dark spots maybe your image pickup sensor going out. Try going into the menu to tools select pixel mapping see if that helps it will look at all your pixels and determine if they are bad & try to compensate.
Hope it helps. Good Luck! please let me Know if this works or if you need more help.
Posted on Mar 11, 2009
Immage not centered and dark corners on pictures
If it's done it on two different bodies than it may be a lens issue(slim chance). Try another lens on your body. Sony also uses a movable ccd instead of moving optic for its image stabilization and may be a bad design and really prone to screw up. I would lean toward a super steady shot problem and the ccd is not lined up right. Personally I've not been impressed with anything sony for a long time, when it comes to DSLRs the only real choices are Nikon or Canon. They own the market and have all the experience and product lines to back it up. In recent years build quality has leaned toward Nikon. I would make sony fix it and then sell it asap before it does it again, then buy something more reliable. Just something to think about.
Oct 01, 2009 | Sony Alpha DSLR-A100 Digital Camera
Subject is dark when looking through the viewfinder
Take the lens off and look at the lens opening on the body - at the 9 o'clock position is the aperture stopdown lever. It should be square to the edge - not bent sideways or too far from the side. It's a pretty flimsy lever and easily bent. You can bend it back square by grabbing with pliers and pushing toward the left side. Common problem.
May 07, 2009 | Nikon N65 35mm SLR Camera
Minolta X-370 Spot driving me nuts!
If its inside the viewfinder, then you'll really need to take it in for a repair, but bear in mind, that will require disassembly and that will likely run you $75-$100, which is more than a used X370 goes for on eBay.
One thing I would check is the underside of the focussing screen as maybe it is on there. Remove the lens and then look thru the viewfinder. If you still see the spot, then its in the body and not in the lens.
Look inside at the underside of the prism - thats where the focussing screen is. Do not touch the screen with any cleaning fluid or your finger. instead, grab something fairly stiff but pliable, like the straw on the edge of a dust blower. and gently rub the general area on the screen where the spot might be. Then blow the area with air to clean it all up. Look thru the viewfinder again and see if that got it.
Its pretty rare for dust to get inside the viewfinders unless they had previously been open for a repair, so theres a good chance its stuck to the focussing screen. Don't touch it with solution or your finger though as the screen can be damaged easily.
Dec 29, 2008 | Minolta X-370S 35mm SLR Camera
Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Aug 28, 2008 | Memorex MLT3221 32 in. LCD TV
Minolta MAXXUM 3xi the view finder is very dark(bought second hand)
I no the older Minolta's had an aperture problem the pictures when zooming out after they were developed were very dark. But inside and wide angel shots always came out nice I had to have the aperture base plate replaced on my Minolta Maxxum 3000i my point and shooter, I wish this helped but it sounds like something different in your case it also maybe the aperture acting different in your camera than it did in 1 of mines.
Jul 27, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Area captured in photo different from area saw in viewfinder
Make sure you look straight through the viewfinder. Keep in mind that the area visible through the viewfinder is slightly smaller than the area captured in the photo. If you're taking a close-up or macro mode picture, turn the camera dial to the LCD mode so that you can use your LCD screen to preview your picture.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Area captured different from viewfinder area
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Metering modes
There are three metering modes: Digital ESP, Center Weighted Averaging and Spot. DIGITAL ESP - The camera meters and calculates the light levels or light level differences in the center and other areas of the image separately. CENTER WEIGHTED AVERAGING - The metering mode provides the average metering between the subject and the background lighting, placing more weight on the subject at the center. SPOT - The camera meters a very small area around the center of the subject, defined by the spot metering area mark in the viewfinder.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Why do two pictures of the same scene, taken at about the same time have different exposures?
Your camera light meter uses the concept of multi-spot exposure metering, which is sensitive to subtle differences in scene composition. To determine the overall shutter speed for a scene, the meter takes readings from three zones within the frame. With Portrait orientations, the zones remain in the same place (vertical) on the CCD imager. With landscape orientations, however, the zones are more spread out (horizontal) and the dominant (2 dark and 1 light or 2 light and 1 dark) zones determine the shutter speed. This may cause some areas of the picture to be overexposed or underexposed.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Nikon Coolpix 4800 Digital Camera Logo
182 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
