Question about Kenmore Whispertone 29512 Vacuum
Power head for Kenmore Canister Vac
Problem with Kenmore Powermate head for a Kenmore Whispertone 12 amp canister vacuum. The circuit breaker in the head keeps popping after a second or so of motor operation. Beater brush turn easily when belt disconnected from motor. Belt in good shape. Seems like a good bit of arcing at the brushes of the motor, but I don't know what is normal. The motor shaft is hard to turn by hand when the belt is removed. Is the motor dying? If it is the motor, is it repairable or easily replaceable?
  • 3 Answers
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Posted on May 17, 2015
SOURCE: Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The model DB9191 is equivalent to the model CB9191 made by the Clean Bloom Electric Co out of China. So if one can track down the replacement HEPA filter for it ...
Posted on Sep 07, 2008
  • 1214 Answers
SOURCE: motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Posted on Jan 22, 2009
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
  • 33 Answers
SOURCE: GE canister vac 106766 power not going to brush head
Try checking the hose connector cord (short cord from bezel outlet to hose). Also, check the prongs on on extension wands.
Posted on May 19, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone 100 connection issues
find a used one at a vac repair shop, its just worn out
Aug 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Need new power brush
Get the number off the power head, it should be on the bottom, then go to Sears.com, click on the parts link, put in the complete model number, a parts list will come up and you can order your part.
Jan 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
364 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
