Question about Toshiba MV13M2 13 in. TV/VCR Combo
  • 790 Answers
Yes you can set the menu function if have menu button is there!
Posted on Mar 11, 2009
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: . The direct link to the manual is . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Re set to factory settings
Go to the front panel of the panel. Manually turn the TV OFF. Via the Front Panel push the INPUT Button in & Hold. Now use the power button on the front of the TV & turn ON the TV.
If done correctly, this will bring-up the TV's Service Menu. In the Service Menu you'll see an OPTION for Factory Reset.
This procedure cannot be done with the remote-it can only be done on the actual device.
Dec 12, 2015 | Hitachi Televison & Video
No remote need to program from front buttons
Toshiba does not make this unit--it has their name---all programming is done from remote via the main menu---Google the model number or call Toshiba to get an original remote---they are not real expensive for this brand in most cases.
Oct 29, 2012 | Toshiba MD13P3 13 in. TV/DVD Combo
I need to re-program my toshiba tv to get basic channels after i just had th cable box removed. how do i re-program it on the remote?
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Jul 13, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
Need owner/user manual for a Toshiba MV13M2W. My neighbor moved and gave me the TV but did not know where the remote or manual were. E-bay has a new remote for $20 FROM EMTC is that a fair price? Is it...
Please rate!
$20 for a NEW remote is fair. There are some cheaper universal remotes from the big box stores but you then have to program it. Some of these universal remotes are tricky with combo units. A new remote would be ready to go out of the box.
Most of Toshiba's products have a manual online than can be viewed, downloaded, or printed off.
Apr 08, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
Can I buy a universal remote for my toshiba MV13M2
Please try and see if the following link help you find a model suitable for the model mentioned.
Universal remote.
Nov 02, 2010 | Toshiba MV13M2 13 in. TV/VCR Combo
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Jan 08, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Toshiba MV13M2 13 in. TV/VCR Combo Logo
605 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
