Question about Samsung BlackJack II Smartphone
Says "NO SIGNAL"
I need to know why my black jack 2 won't get signal.
  • 38 Answers
This is a general cell phone question
typically if you are in a city you'll get weak reception
often times you'll need to stand next to a window
or get away from brick walls and steel buildings
Posted on Mar 11, 2009
I need to know the diagram forthe5 different colered wires that attach to he female jack inside the speaker. i soldered 1 and tore the rest off by accident and i dont know where to solder them back on
Get 3 cables with mini alligator clips, from Radio Shack or other electronic supply store and use the old trial and error method. Better yet do you have a volt meter? more than likely 2 wires are power and power ground and the other 2 are signal and signal ground.With a volt meter you should be able to detect the power and the signal. Use the DC volt setting on the voltage meter.
Apr 29, 2014 | JBL Flip Portable Stereo Speaker for Most...
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
Can I hook up Altec Landsing VSA3251 to my TV? the plugs do not seem to be the same
you can hook it up to your tv if you have a 3.5mm headphone output jack on the tv :) any powered speaker can get a signal from that jack. mind you, this is only a stereo signal so if you are running a surround setup 5.1 and up you won't have all the channels for your speakers.
Jun 11, 2011 | Altec Lansing 4100 Computer Speakers
NO SOUND WITH EVERYTHING PLUG IN .
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
I need the wire color code for a 1999 toyota camry o2 sensor
Well - I'm not sure which one you mean - front or rear - here is a wiring diagram that should help you though.
Sep 18, 2009 | 1999 Toyota Camry
Need to resolder my wire back to the jack - it was ripped apart by an agressive 3 yr old v-moda vibe black
The tip is the left signal, The ring is the right signal and the sleeve is the ground/shield. I hope that helps.
Mar 31, 2009 | V-Moda Headset VIBE in Gumetal Black...
Changing the output Jack on 1985 Peavey Dyna Bass
If this has active circuitry, one of the wires is the cutoff for the power supply from the battery. The other two are black for ground and either white or red for signal.
Mar 13, 2009 | Peavey Music
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Samsung BlackJack II Smartphone Logo
121 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
