Question about Samsung SCX 4521F All-In-One Laser Printer
LSU ERROR MESSAGE ON little screen when photocopying
LSU message always appear on screen when photocopying
    President:
  • 1,566 Answers
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Posted on Feb 09, 2010
    New Friend:
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU erorr appear in display screen
LSU refers to the long strip of glass / encoder strip inside the top of the cartridge compartment. It could be dirty or dislodged.
Power off the printer
Open the front cover
Lightly pull out the cartridge and keep it flat
Gently swab the LSU. If part of the LSU is hanging, gently put it back in place and reconnect. Be careful not to touch anything else.
Note: If you are unable to reconnect the LSU, the printer will need service.
Put the cartridge back (again, leave it flat).
Close the front cover.
Power the printer back on.
Hope this helps.
Jul 28, 2009 | Dell 1600n All-In-One Laser Printer
Sharp Photocopie SF 2035- warm up problem
Dose the copier show a error code? Like a H4??? If so you have a problem with the fixing unit. I do belive it can be reset, but the problem needs to be repaired aswell.
Jul 26, 2008 | Office Equipment & Supplies
Photocopier Sharp ar201 not working
L6 - Polygon Motor Lock: The lock signal (the specified rotation speed signal) is not supplies within the specified time (about 6 seconds) after starting the polygon motor rotation. LSU connector disconnection of harness disconnection in the LSU. Replace LSU.
Aug 01, 2007 | Sharp AR 201 Copier
Samsung SCX 4521F All-In-One Laser Printer Logo
845 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
