Question about GE Refrigerators
RUNNING WITH LOAD NOISE, HIGH PITCH - GE Refrigerators
  • 5 Answers
I had this same issue and it was driving my wife nuts. Supposedly women hear high pitched sounds better than men? I called my local Appliance Parts Store, I advised them of my problem. My model # is GSH25KGRE BB GE Side by Side. (4 years old) They sold me a evaporator motor for $ 42.00. I was advised that this motor is accessed through the freezer door. After unplugging the refrigerator,I took the first self below the ice maker out, I removed the plastic light cover, there is a plastic piece with 4 slots in it, take the two 1/4 screws out and bend that plastic piece up. You will see the motor housing which needs to be removed I believe there are four more 1/4 screws. The motor itself will have a white fan attached to it which you will use on the new motor. Remove the fan via 4 more 1/4 screws you will also see the wire harness going up through one of the plastic pieces. This is where I had a little trouble, I couldn't get the harness to come apart from the plastic piece, I was afraid I would break something as hard as I was pulling. I decided to cut the 4 wires (red,blue,white,yellow) close to the old motor and splice in my new motor after cutting off the plug. I reassemble the unit and it solved the problem. I am the hero at our house and saved us from having to buy a new unit. My wife wasn't going to take it much longer. This is the part # WR60X10185.
Posted on Apr 22, 2009
  • 400 Answers
The high pitch is probably caused by a bearing on the fanmotor which is dry or worn and needs replacing. Rate me.
Posted on Mar 11, 2009
So how do i replace. Have my eighteen month grandson here with a cold and it is making the noise now?
Posted on Apr 08, 2009
Nosey new refrigerator has high pitch or low noise irritating
is it an inverter fridge which saves on energy. that makes a high pitch sound. i recently fell into the same trap. if it has a clock set the time so its more inclined to make those noises when you are asleep.
Sep 30, 2016 | Whirlpool Refrigerators
High pitch intermittent noise
Check your fan and clean it up
Sep 08, 2014 | Samsung RF4287HA
I have a GE Model #GSS20IEPJWW. It started having a high pitch sqealing noise when running. Now the noise has stopped, but now the top of the freezer and the frig side is warm.
the squirrel cage fan motor is squealing,can be lubricated with a graphite or some sort, lubricating with any type of oil might cause a dirt build up on the shaft causing later problems
Jan 22, 2011 | GE GSS20IEP Side by Side Refrigerator
High pitch whistling noise
It can be either the compressor fan motor or evaporator fan motor. OR often if there is moisture in the gas line, there is a whistling or ghosting noise. If all is running well then you could just leave it until a problem arises
it until eventually the com
Jun 13, 2010 | KitchenAid Refrigerators
Fridge making annoying high pitch noise almost constantly
mine had a recall on the chipboard. fixed the high pitched buzz, but now i can hear the motor running stronger.
Oct 07, 2009 | Fagor 3FCA-68NFX Stainless Steel ...
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is making this high pitch noise, its an industrial Beaufort freezer on wheels
Zaria:
I have the same kind of fridge and it also makes this kind of noises, however, they are on the acceptable level. They sound more like a seal being happy with the new food. It is not all the time but sometimes. I think it is the contraction and expansion of the pipes that cause the noise and is not a sign of any problem. Of course all depends on the level of the noise you have...
Hope it helps. Greg.
Apr 17, 2009 | LG LRTP1231W Top Freezer Refrigerator
Hss25gfpdww The unit makes a horriable high pitch whining noise a
I am not posotive, but it sounds like you may have a piece of debris stuck in the fan underneath. You can check if you pull it out from the wall, make sure you unplug it as to not have the fan come on while you are toying. But thats what it sounds like. If that is not it, I am sure you could locate the noise with it pulled out from the wall, and go from there, Possibly your compressor, but sounds like the fan the way you're explaining it. Good luck
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge is making noise
The high pitched sound could be from the evap fan motor. If you can get to it a drop of silicon oil would solve the problem.
Dec 18, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
615 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
