Ilo 42'' says no signal on VGA when connected to a computer
My plazma tv says no signal on VGA input when connected to a laptop
  • gelhead50 May 24, 2009
    Whenever I connect my laptop via the VGA input, the TV says "not support". I had it working once but I had to unplug the cable to hide it behind my desk. I tried again with the same options and settings, but nothing works. At first I thought it was a resolution issue, but I tried every possible combination.
Snap off/fully remove pins 11, 12, and 15 from a spare VGA cable and use this to connect the ILO tv. These pins are used for identification of the monitor by the PC. The video signal is now displayed perfectly on my ILO tv, in all supported resolutions.
Posted on Jul 17, 2010
Flashing blue and black on the screen
Hi there , if you can activate menu on screen , then try to change the video input source to something like VGA , and be sure that You've connected some video source with VGA cable prior to this. Sometime when there is no input signal (especially digital like HDMI) it flashes like that. Hope this helps .Cheers.
Dec 05, 2013 | ViewSonic Computers & Internet
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at
Mar 22, 2013 | Panasonic 50 in. Plasma TV
Having problem connecting inspiron 1150 laptop to tv via vga
Check the remote for the TV or the TV menu to see if there is a way to change from one source input to another. You may just not have the TV set to the VGA input. Also you have to make sure the video card on your PC is set to a resolution your TV will support.
Dec 04, 2012 | Computers & Internet
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
I have a Panasonic Viera tx l37g20b and i am attempting to connect it through a VGA cable. I have connected the laptop to the TV, but there is no option in the TV's menu to select the laptop as the input...
You should have a SOURCE select button on the remote control to select the input source. This should allow you to select the VGA input as the input source. You will also need to make sure your laptop is configured to output a signal via the external VGA port.
Mar 20, 2011 | Panasonic Televison & Video
My flat screen says no signal when i try to watch a movie from my laptop, what do i do?
Hello Nabrowne Hi, Use the input selector on the TV menu, if still no success try a different cable for your flat screen. there are several input you can use, the common one is the VGA, and the sVideo. connect the VGA cable to the TV. then on the menu select VGA/PC then on the laptop find the Fn functions that send the signal to the TV.
Jan 03, 2011 | Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
How do I connect my laptop to my TV wiyh a VGA
do you have a VGA input on the TV?
If not, you need a PC to TV converter.
Link Here:
This ITV-900 is a one piece PC to TV Converter that lets you show computer presentations, play games and watch DVDs on TV. It converts your computer's VGA signal to your TV's S-Video and video output signal!
The PC to TV converter supports up to 1024 x 768 resolutions, NTSC/PAL television system, auto fine tuning and more! This ITV-900 is compact, portable and easy to use!
Nov 26, 2009 | HP Pavilion zd8000 Notebook
Televison & Video Logo
903 people viewed this question
Top Televison & Video Experts
