Question about Sailrite Ultrafeed LSZ-1 Mechanical Sewing Machine
How to oil a sailrite lsz-1 sewing machine
We have a borrowed machine and some expeience, enough to know we should oil it, but where ? and where could we download a manual, hopefully for free. Thanks
SOURCE: Sewing manual for a Reliable or Sailrite
The problem is that you purchased a clone of the Sailrite Ultrafeed. Most people do not know how much work Sailrite puts into each Ultrafeed Sewing Machine before it is shipped to customers. They hold 17 patents on the Zigzag Ultrafeed and know this machine inside and out. So when each machine goes through the assembly line in Indiana they are then tested by Sailrite in 2 layers of canvas then 8 layers of canvas then 4 layers of vinyl fabric if it does not sew it flawlessly they fix it, Ultrafeeds work right out of the box! So, it is highly unlikely that you will be able to get the clone machine to work. It must be totally rebuilt (a 4 hours process for an experienced technician). Sailrite will not work on any clone machines. So get your money back and buy a Sailrite Ultrafeed! If you are desperate and can not return the machine you can buy a DVD that Sailrite made for the Ultrafeed (each Ultrafeed purchased gets it free) it can be purchase here: http://www.sailrite.com/Ultrafeed-Advanced-Maintenance-DVD . It will help with timing issues, but will not show you how and what to do to rebuild the machine.
Posted on Jan 01, 2009
Sailrite Manual
Call or email Sailrite, they make the machine so one would guess they have instruction manuals...
Sailrite Enterprises, Inc.
2390 East 100 South
Columbia City, IN 46725
Store Hours
Monday - Friday: 8am - 5pm EST/EDT
800.348.2769 (toll free)
260.244.4647 (local)
260.818.2005 (fax)
sailrite@sailrite.com
Apr 03, 2014 | Brother CS6000i Computerized Sewing...
Fabric bunching sailrite
try easing both bobbin and top thread tensions
Dec 25, 2013 | Sailrite Ultrafeed LSZ-1 Mechanical Sewing...
Is the Riccar 9800 heavy duty enough to sewing a bimini top for sailboat?
I would suggest you go to the link below, called sailrite, they have a online
chat, ask them what sewing machine they would suggest for the fabric
& plastic you want to use, I've been sewing for over 30 years & it's better
to get a sewing machine that will do what you want the first time, rather
than get a sewing machine that says it can but can't deliver.
http://www.google.com/aclk?sa=l&ai=CxoOTr05TUPGlBcSyiwLEu4CoD4Pfl6YC05_d6SPZzYz1AQgAEAFQ_oGf3fj_____AWDJ1pOKnKSEFKABp92G_wPIAQGqBBtP0FXPk9hFVfPtYXR3y3fbvFbJFhaGFLCfDbG6BRMI8da92rK1sgIVygJCCh2fKQAAygUA&ei=rk5TUPHHA8qFiAKfUw&sig=AOD64_2SRGrr_UIczmwA9-VEHRlvz4TLIw&sqi=2&ved=0CB0Q0Qw&adurl=http://www.sailrite.com&rct=j&frm=1&q=sailrite
Sep 14, 2012 | Sewing Machines
Where can I buy an electrical supply and foot control for a Thompson Mini Walking foot Model PW 201
Almost any dealer will sell a replacement part for the sailrite. Its a standard type controller, the cost is 40-80 depending on the quality of the controller and cord. Take the machine in the shop and try to be sure its a correct fit. Sailrite has a mail service as well.
Derek
Jan 18, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Looking for user manual for Sailrite LS-1 and a source for a basic case for the same.
Go to the Sailrite site, open the "sewing machine" menu and choose "accesories". The is a case on the list which might be suitable.
Although I couldn't see any instructions option, the manufacturer should be able to supply one if you ask them, since they pubished it in the first place.
Dec 18, 2009 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
The top thread is coming out of the needle, how do I fix this problem?
check and see if the take up lever is in the down position when you cut the threads, if so it will pull the thread out of the needle on the first stitch always keep it in the up position when threading or removing the fabric
Oct 28, 2009 | Sailrite Ultrafeed LSZ-1 Mechanical Sewing...
Basic instruction to use the Sailrite Ultrafeed LSZ-1
I CAN'T HELP YOU WITH THE MANUAL, BUT I CAN TELL YOU THAT MOST MACHINES THREAD ABOUT THE SAME. IT SOUNDS LIKE THIS MAYBE A COMMERCIAL MACHINE, AND I WANTED TO WRITE JUST TO TELL YOU TO BE VERY CAREFUL. WITH A COMMERCIAL MACHINE YOU CAN SEW OVER YOUR FINGERS WITHOUT EVEN KNOWING. FOR EXAMPLE, SAY A REGULAR HOME SEWING MACHINE HAS 1,500 rpms, THE EQUALIVENT IN A COMMERCIAL MACHINE IS 15,000 RPMS. THERE IS POWER AND SPEED. I AM NOT FAMILIAR WITH THIS PARTICULAR MACHINE, BUT WANTED TO TELL YOU TO JUST PUT THE BANDAIDS ON YOUR FINGERS FIRST, BECAUSE IF IT IS A COMMERCIAL MACHINE, IT WILL REQUIRE YOU TO DO A LITTLE BIT OF PRACTICE FIRST BEFORE YOU "PUT THE PEDDLE TO THE METEL".
Aug 11, 2008 | Sailrite Ultrafeed LSZ-1 Mechanical Sewing...
May 21, 2008 | Sailrite Ultrafeed LS-1 Mechanical Sewing...
Sailrite Ultrafeed LSZ-1 Mechanical Sewing Machine Logo
183 people viewed this question
Top Sailrite Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Debbie
Are you a Sailrite Sewing Machine Expert? Answer questions, earn points and help others
