I have a mitsubishi wd-52525. i have sound but no video any ANY of the input ports. i CAN view the tv menu, volume bar, channel numbers, etc....
  • 6 more comments
  • candmduncan Mar 11, 2009
    i have a mitsubishi wd-52525. i have sound but no video any ANY of the input ports. i CAN view the tv menu, volume bar, channel numbers, etc....
  • candmduncan Mar 12, 2009
  • candmduncan Mar 13, 2009
  • 19,396 Answers
If you are using an external receiver, try using a different cable and a different receiver.
Ensure that you do not have PIP or zoom functions active, try using PIP commands on remote.
Try unplugging the TV overnight to reset.
If all that does not work, then it can be a faulty video circuit, problem on dmd board, problem on tuner board.
In that case you will need a technician to fix the problem.
Posted on Mar 16, 2009
  • 4,234 Answers
This may sound a bit odd, but the problem is on the PIP module. All video signals pass thru this module. The reason you see hte menu etc, is that those signals are generated in a separate pathway that is merged with the video signal later on. There is a repair kit for these sets that is available for about $14. It includes all of the surface mount capacitors that fail.
Dan
Posted on Mar 13, 2009
    Sergeant:
    Champion:
  • 435 Answers
Open the unit and look for any burnt capacitors.
Replace them if you find so.
Posted on Mar 12, 2009
  • 583 Answers
Its faulty tv input module.that cannot be repaired the inner board needs to be replaced.will cost you near to $ 150 for new.board or you can take the board to repair center they will try to get it repaired if possible.
Posted on Mar 11, 2009
    Sergeant:
    Novelist:
  • 277 Answers
Get the replacement cables from  radio shack web sites and also get the input /output port connector. donot  connect the wires directly to the unit.connect the wires first to the input/output port connector first then to the unit.and then check it will work as new and the picture will be perfect.as in the box you can also set the mode on what you what to watch the pictures.its a common problem solved by many customers facing the problem like yours.
    Sergeant:
  • 300 Answers
Its the problem of the ports where you insert the wires.the video ic and card internally is proper.you will have to resolder the ports which are connected internally .they tend to get loose many times creating this sdame problem.but a professional has to do the job because the ports are very delicate internally and can break up if mishandled or applied force on them to solder.
thanks.
  • 3,037 Answers
Sounds like you have cold solder joints, or solder joints on the mainboard which have cracked over time due to thermal expansion and contraction of the circuit board.
Repair is to find and reflow the cracked joints. You may want to consider hiring the services of a reputable repair professional to deal with getting your set back into normal operating condition.
In the meantime, stop using that tv in its current condition! Continued use in that state could make the problem worse or create new headaches that may only allow for a more expensive repair bill.
I recommend having a service shop near you do the repair if you don't have prior electronic repair experience.
Benjamin
    Sergeant:
  • 320 Answers
Its the problem of connecting wires just remove and reconnect it properly. if still the same problem then it might be inner board problem.that needs to be checked with a meter to locate the faulty on main board.
  • 790 Answers
Hi
please check the menu settings if the input mode is default mode... or maybe you have defectitve video driver thats why no input video...
Thanks
  • carlos fernandez Jr.
    carlos fernandez Jr. Mar 12, 2009
    this issue nedds to diagnose for a qualified technicians to find the trouble parts in PC board...
    Thanks!
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
Model wd-60737 no volume
Look first to see if sound gone on all inputs---use a DVD etc connected to a input
Make sure in the menu speakers are not turned to OFF
last resort try the soft restore this model should have--menu, 1,2,3 enter
Set also has a hard reset but uses a different code I do not have.
Dec 05, 2012 | Mitsubishi WD-60737 TV
Hdmi input for playstation 3: when i connect my playstation 3 to the hdmi on tv the menu section of the game does not show correctly. i have to guesss the controls to select to play the game then the game...
Try using a different HDMI port on the TV. It may be you are plugging it into a the DVI-HDMI port, which does not display FULL HD, or carry sound.
Hope this helps
TV_Doctors
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cannot hook up my playstation2 to my mits wd 52525
on the set you have to go in to the menu and turn on those port so you can play. it should be under inputs the turn on the one you are using. if that dos not work let me know.
Aug 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No Remote need to set up for DVD Video (Mitsubishi Medallion HD 1080)
What you do is match color with color, just make sure if you are putting in Video 1, 2, 3 etc. then you have to set your tv to that input with that Device/input button.
Mar 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound but no Picture on all inputs but the RF
No its difficult to change any boards in this model (they're all package together in one module).
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
