Question about Dell Inspiron 1525 Notebook
System not functioning in my laptop?
I have tried to back up my files but the system isn't functioning at all how should i do with this problem?I think its because my laptops is infected with the worm virus
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Obviously, you want to save files from the computer; any files transferred to another system could infect that system.
If you really need those files I would recommend downloading an Ubuntu ISO and burning it to a CD. This gives you to boot to an operating system from a Compact Disc.
http://www.ubuntu.com/getubuntu/download
Ubuntu Linux has the ability to browse the Windows hard drive, if needed, transfer the files off the partition. You can burn the files from Ubuntu, if you have two Disc Drives, move the files on to a Flash Drive, or you can transfer them across your home network. Beware, this can spread the damage to other systems that do not have active virus protection.
Seriously, you need Norton, McAfee, or AVG Free at the least; these programs can intercept virus like activity as it happens in the memory. Furthermore, a script blocker like Noscript, Ad-aware, or MS Windows Defender can help prevent Spyware/Trojans/Variants from installing when you browse a untrusted site.
Once you have backed up the files you want to save you'll need to use your system recovery disc to format the hard drive and reinstall the operating system on your laptop.
Posted on Mar 11, 2009
MSI U100 FUNCTION KEY COMMANDS NOT SHOWING ON SCREEN ANYMORE
That is quite common and can be windows updates or spurious downloads that corrupt the system files. Restoring the complete system will bring it back but it may be something to do with either the system drivers or keyboard driver. Try downloading fresh drivers from msi.
Jan 31, 2014 | MSI Wind U100-030US Laptop
Motherboard model troubleshooting
troubleshoot motherboard
Back up everything possible on your hard drive.
If you're experiencing hardware issues, this is a luxury you might not have.
Keep backup files on an alternate data storage system to avoid data loss during hardware problems.
Notice the issue and reproduce it so you're aware of where the symptom manifests itself.
Isolate the problem.
If the system isn't getting power, make sure it's not the power cord or wall outlet before you try a different motherboard.
If everything is trying to run but not actually able to, check for loose parts on the motherboard before you replace it.
Remove all of the hardware that isn't actually necessary to make the computer function before you can narrow down the causes for your problem to the motherboard.
Ensure that all cards and memory units installed on your motherboard are securely in place and that each is making a good connection.
This can be accomplished by removing each component, blowing out the socket with compressed air and replacing the components.
Try another compatible motherboard in your machine once you've eliminated all other potential problems.
If it works with the alternate motherboard, replace the old one.
hope this helps
Oct 11, 2012 | Intel Computers & Internet
Error opening operating system
First try to use your operating system disk to repair the problem using operating system repair option.
If this does not work and you expirence the same problems you could try restoring your Operating System but first back up any files you would like to keep.
At any rate back up your files now! In case your hard drive is failing.
To do this get an external enclosure for your drive and load it up on another windows based PC then back up your files. If you have no important data then try a clean install of your windows version. it may take several drivers and updates not to mention hours but it will be done.
If it is your hard drive failing you should receive a message indicating this otherwise it could just be corrupt system files or improper installation or deletion of materials that are required for the OS to function.
If it is not this it could be something like your main board video chipset possibly overheating in which case you can try and have it repaired or buy a used working motherboard for your laptop and replace it with some patience and some hours and a little bit of cash you could have it back in working order.
May 26, 2012 | HP Computers & Internet
Windows internet explorer not working
was explorer working perfectly on your computer previously? If yes, you can try system restore.
System restore can help to back date your computer to the time when explorer was working.
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe if explorer will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jan 05, 2012 | ASUS Computers & Internet
How to reset hp compaq nc6220 to factory settings
SYSTEM RESET
Warning - You may loose all of your saved files - Back-UP first!!
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you may loose all of your files and after market downloads.
Back-UP first!!
That's worth 4 thumbs up!
Aug 19, 2011 | HP Compaq nc6220 Notebook
Unable to boot Windows Vista Dell Inspiron 1545 I have tried starting it in safe mode, I tried doing the startup repair, I've done the boot from Utilities & Drivers CD that came with the computer...
Well if your problem is to back up your files, you already said that you can get into safe mode, you can attach an external hard drive or flash drive to copy your files from local drive. Remember to activate your OS system restore if your able to succesfully restore your system with your CD. You can change that settings on properties of "my computer".
Jun 17, 2011 | Dell Inspiron 1545 Notebook
Acer Aspire AX1300-E1820A will not turn on. even if hot wired, I didnot back up my files Help please
Worst case scenario: extract the hard drive from the Aspire (usually its just 2 tiny screws holding
the HDD), and plug this PCMCIA-bus drive into another (functional) laptop. Windows will
mount the drive (but not load the OS). Extract the files using the functional PC's operating system.
In future, always back up your files, or even better - keep no files on the laptop at all - do this
by storing ALL your files to a flash drive. That way, the system can crash an any time (and they do),
and you lose nothing.
Mar 28, 2011 | Acer Computers & Internet
If you didnt backup your files and you need to reinstall your operating system (or run a system recovery), you have a hard choice to make...delete the files while recovering, or try to treat the infection and save your data. A good technician can save your files and fix the machine. Do you have a hard drive enclosure and a second computer to connect it to? If you do, then theres hope. Otherwise, make that painful choice.
Mar 11, 2009 | Dell Inspiron 1501 Notebook
Corrupt File System
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows.
So copy/paste the data you don't want to loose and then go to
My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
May 20, 2008 | Western Digital Passport WDXML800UE...
Dell Inspiron 1525 Notebook Logo
74 people viewed this question
Alun Cox
