Question about Acer Aspire 5735-6694 Notebook
DOWN LOADED AT&T COMUNICATION SOFT WARE FROM AN AIR CARD. CAME TO RESTART, MACHINE SHUT DOWN AND NEVER CAME BACK UP WENT TO BLACK SCREEN ON ME. THIS IS AN ACER ASPIRE 5735-6694. GOT THE COMPUTER REPLACED AND WANT THE AIR CARD BUT DON'T WANT ANOTHER CRASH. IS THERE ANY THING TO DO TO PREVENT THIS? DAVE
  • bigdaves40 Mar 11, 2009
    I WENT THROUGH THE SAFE START AND RECOVERY OF SOFTWARE AND STILL DID THAT. THEN HAD THE UNITE REPLACED. AT&T SAID THEY HAD PROBLEMS DOWN LOADING THEIR COM. S/W TO ACERS IN PAST CAUSEING A CRASH. I WOULD THINK THERE MUST BE A WAY AROUND THIS.
  • 98 Answers
Hello i think i can help you.As long as you are running xp or better software.you should have no problems.as for the computer not starting.put your operating system cd in the drive.and if for some reason the drive wont open.they have a trick for that to.with the computer off.take a paper clip and insert it in the tiny hole look and you will find it.push the paper clip in the hole and the drive will open.now put the operating system disk in the tray and close slowly.now reboot computer and follow the prompts.
Posted on Mar 11, 2009
  • 10,515 Answers
Ctrl Alt Del
You would be able to see diff. options. Try that.We need to remove that screen even if we have to use safe mode.
If you are not getting these options, Bios issue. we might need to format your pc.
Thanks.
  • taran_2005
    taran_2005 Mar 11, 2009
    Or Use the button on noteb ook to shut down.Aftr few minutes try to enter it into safe mode.
    Thanks.
  • taran_2005
    Go to uninstall and uninstall this. Unless go to drive C.
    Look for program files, there would be a folder for at and t, delete that.
    Thanks.
  • 3,037 Answers
I doubt the card was the problem. Sounds like a coincidence that it crashed the last time. Most likely you just had a hardware problem if it wouldn't even turn on. Nothing really to prevent it, it should work on the laptop.
Benjamin
  • Acer Master
  • 13,433 Answers
It shouldn't cause the computer not to work anymore, whats the brand and model of the card your using with the laptop? if it doesn't start up after installing, press or keep tapping f8 before windows loading picture comes, and when the advanced options come up select safe mode.
    Sergeant:
  • 320 Answers
Check out by removing the battery first.if still the same problem after reinserting.and unit under warranty get it replaced.
I am uable to listen any type of sound from speaker and in device manager it is not showing option of enable disable it is showing only hardware scan and properties
Shut the computer down and remove the sound card, restart the computer without a sound card installed then shut it down again. Re-install the sound card and make sure the monitor is connected before you restart. The computer should have seen the card and loaded the correct driver. If you are still having problems shut down and restart in safe mode and troubleshoot.
May 19, 2011 | Compaq Audio card Sound Card
Dsi will not play R4i card since updating system
This happened to me you just need to put r4 software on card download r4i update put that file on card then put card into original ds (old version) cliick on update let it run power off when told put back into dsi and all should be fine hope this helps it worked for me !
Oct 07, 2010 | Nintendo DSi Black Console
I have an r4 card i have down loaded the soft ware and all is ok, when i download games on to the card reader it shows up on the computer but wont play on the ds
OK first off, it could be a problem with the R4DS card. If you are using it in a DSi, you should buy the R4i and make sure you have Firmware 1.3 NOT 1.4. Second, Nintendo made those illegal I think. Check ap.nintendo.com
Feb 26, 2010 | Video Game Consoles & Games
Error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
Aug 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Wont boot no bios screen nothing
Check your memory card. Reseat or clean its edge connector with soft eraser.Do this after you shut it down properly , battery disconnected, and no any other power source is connected.
That is the first thing to suspect. Or try it also with a spare good ram card.
May 09, 2009 | Everex StepNote XT5000T Notebook
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Acer Aspire 5735-6694 Notebook Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
