Question about ASUS P5RD1-VM Motherboard
Hard Drive Not Recognized
I finally completed assembling the PC, started it up and I was able to update the BIOS settings, rebooted and here comes another issue. When I tried to install XP, it does not recognize the hard drive. I decided to use an old hard drive from another PC with Windows XP Home complete with updates installed on it and my newly built computer does not recognize the hard drive. Before I can do this with my other systems, I just have to reformat the hard drive and I was able to install a fresh copy of Windows. Any suggestion?
  • 2 more comments
  • Sonny Hibo Mar 11, 2009
    It is an IDE hard drive with a Windows XP Home in it.
    It says in the manual that I have to install a driver for the "ITE 8211F controller" before installing the operating system. I connected the hard disk to the "PRI_PCIIDE 1 (black)" and the optical drive to the "PRI_IDE1 (blue)" for better performance. How will I install the driver for the conroller before installing XP? Thanks in advance for your help.
  • Sonny Hibo Mar 12, 2009
    My PC is up and running. I installed a new Seagate 250 GB SATA hard drive which I bought for $ 30.00. I really want to thank you for all the support you've given me. More power to "FixYa."
  • RSBennett
    RSBennett May 11, 2010
    Is this an IDE hard drive or SATA hard drive?
    If it is an SATA drive, you will need to load drivers via floppy disk during the Windows XP install.
    Let me know if I can help.
    Scholar:
  • 54 Answers
It is rare that an IDE drive will not be detected during Windows XP setup. Try the following steps:
1) Verify that all connections are solid. The IDE cable is secured at the drive as well as the motherboard. The power supply is connected to the drive.
2) Enter the BIOS setup and verify if the drive is recognized there. If not, there is a connection problem.
3) If you are using any type of RAID, even if the drive is simply connected to a RAID controller, you will have to load those RAID drivers via floppy during the install process in order for your drive to be detected by the Windows installer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Posted on Mar 11, 2009
  • RSBennett
    RSBennett Mar 11, 2009
    This is one of the downfalls of installing Windows XP. For any SATA drives or RAID configurations, you have to install drivers during the installation and you can only do this via floppy disk. Here's the process:
    1) Make sure you have a floppy drive for the PC. Either you've already got one installed, or you can harvest one from another PC, or you can use a USB floppy drive.
    2) Obtain the drivers that you need. Hopefully, they came on a disc with the motherboard. If not, go to the MB manufacturer's website and download there.
    3) when you find the drivers, you will find a folder with a few files, including one named txtsetup.oem. This set of files are what you need to put on the floppy disk.
    4) Start the Windows XP installation from the CD - without the floppy disk in the computer. As soon as the installation starts, it instructs you to press F6 if you have additional drivers. Press F6 and insert the floppy disk.
    5) After a few minutes, a screen will come up instructing you to insert a floppy with the drivers. Follow the onscreen instructions to load the drivers.
    6) Continue the Windows XP installation process.
    Hope this helps.
  • RSBennett
    RSBennett Mar 12, 2009
    Glad to hear everything worked out! Please let me know if I can ever help again.
    Problem Solver:
  • 7 Answers
Make sure all wire connections are completely pushed in. try going in to the BIOS and see if it reconized it
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
I have a gateway performance 1400 desktop. Got it 10 years ago. has a 20GB hard drive. bought a western digital WD800BB 80 GB hard drive. installed it into system and it is not recognized. I think I need...
Hello
I dont think you need a bios update. The new drive.. is it set as a master? There should be a small jumper in the back. Master . Slave. Auto. Set the jumper to master.
Next.Take a good look at the ribbon cord and be sure its installed correctly on the back of the drive and on the motherboard.
Last.. reset the bios by using the jumper to clear c mos on the motherboard.
Aug 23, 2011 | Gateway Performance 1400 Notebook
I have a compaq s5100nx desktop with a crashed 80 g ide hard drive.i am trying to replace it with a 500 g drive but the drive is not recognized by the bios i have tried 2 different drives already. However...
did you configured the Hard drive jumpers correctly?
Was the original HD set to master or Cable select?
if so please set your new hard drive to the same jumper settings as the old one.
Mar 19, 2011 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
My hp compac come on powers up, but will not go on line, will not recognize the disc drive , will not recognize any USB ports and when I go to shut down, it will sit on the "shutting down" screen for...
just a mobo huh, no PC, there.
so what PC did it come out of???? HP what? desktop .
turns on, ok
will not recognize the disk, (what disk? what drive, what disk,??)
floppy, PATA HDD, SATA HDD, or CD drive.?
will not recognize, USB ports. (in BIOS or in Tne OS)
what OS, windows 3.1? what/? what Operating System??????
what OS will not shut down, and installed by whom and what media>?
take this unstated PC and install the OS, as it came new.
This PC is so old its not supported by HP, now.
so find and install disk (media) and re-Install the OS.
Fresh.
there it is, Google fails to find the match to any HP PC model name.
HP has zero data on it, now, its too old.
Jul 13, 2017 | HP (D7580-60003) Motherboard
2nd hard drive dissappeared from windows
first of all. you will need to check on the BIOS if the hard drive is being recognized. if it's not recognized, try to use another sata cable and plug it on another sata socket on the motherboard.
if still not recognized, probably its fried. if you get the info of the hard drive on the BIOS, go to windows and then go to computer, right click it and click on manage. click on disk management on the left side of the screen and then you will see on the right side all the information of all the recognized hard drives. if you see the missing one in here, most probably the information that was here is already lost, but you can right click it and then click on initialize, and then reformat the drive to use it again.
Dec 12, 2009 | Computers & Internet
Sony Vaio PCV-RS720G not recognizing new Seagate Hard Drive. When I first installed the drive with XP OS running, the pc recognized and formated the drive. Since then the original drive that I was going to...
This should be a quick fix. How old is the machine you are trying to update? Do you know if the jumpers on the drive are in order? Is it a SATA or ATA drive? Did a CD or Disk come with your drive? Check jumpers on your old drive and make sure the jumpers on the new drive are similar ( master, slave, cs ). Usually leaving on Master is best. Is anything else on this line, like a CD or DVD? I think you'll get it from here.
Nov 10, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Sata hard drive not poping up
just enable your sata by going into your bios/cmos. configure it there save your changes and reboot our pc.
Jun 22, 2009 | Acer Aspire E500 PC Desktop
Computer will not boot, and makes error sounds
If you mean the computer is emitting a series of "beeps", then I would try reseating the memory modules. If that doesn't work, try using only one memory module at a time to determine if one might be defective.
Oct 16, 2008 | Dell Dim.9150 Pentium D 820 Dual...
ASUS P5RD1-VM Motherboard Logo
403 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
