Question about Delta 36 T30 T2 30 Inch Fence And Rail System
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
My Sears Craftsman 9" Table saw has a cast iron table 20" deep. Today's 10 " saws are mostly 27" deep. Will a Delta 36-T30 T2 Fence and rail system fit and work? I think the fence has a bushing that rides on the rear guide rail. Is this bushing re-locatable from 27 to 20 inches?
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Posted on May 15, 2009
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
Changing volage on table saw
usually on the back of the plate where the wires go into the motor there is a wiring diagram for changing the voltage. UNPLUG saw first before removing the plate. Let me know if you need more assistance and I will try and help
Dec 30, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
When I flip the switch it foes not run. I used the saw for several cuts, I tried to rip another pirce and it just wold ot run. Tried the rset button and it seems like it is stuck. Wwiriing is all...
Sometimes switch gets dust inside the "sealed" switch. Had 50/50 luck taking apart and blowing out. Can test it after switch is out to see if it is faulty by jumping wires.
Aug 26, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
Blade is not parallel to the channel. How do I adjust it?
Instruction manual for your saw is here. See Page 21. You need to adjust your blade alignment to the miter slots. As mentioned in the manual, there are a couple bolts that hold the rear trunnion in place. Loosen them up, shift the motor a bit (not an easy task). Keep checking blade alignment until you've got it down.
There are after market trunnion alignment kits for table saws that make this a bit easier. Check out PALS (Precision Alignment & Locking System). For $20 or so, it makes the process MUCH MUCH easier.
If this post was useful, please vote. Thanks!
Mar 28, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
The front and back of the blade are not square to
use a square to sure up your blade so you are at a true 90 degree
Jan 16, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I need a manual for a very old cast iron 10 inch sears craftsman table saw. Sorry, no model number
Have a look here. Given the lack of a model number, that's the best I can offer, I'm afraid.
Good luck.
Aug 31, 2009 | Craftsman 10" Table Saw
Delta 36 T30 T2 30 Inch Fence And Rail System Logo
1,498 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
