Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Mouse clicks don't work
I'm using Windows XP Pro on an Acer Extensa5620z laptop. Since yesterday, mouse clicking just doesn't work in inactive windows. What I mean by that is that I click on whatever aplication window that's in the background (or tabs in Firefox, adress bar vs. inside the website page), it just doesn't switch and doesn't react at all to buttons, menus etc. Both the touchpad, USB and bluetooth mouses react all the same way, even after reinstalling drivers. Therefore, it seems it's an internal Windows explorer or registry issue.
If I want to click on buttons,links etc, I have to call up the task manager first via ctrl+alt+del and click from there to make it work. It's a major pain in the ***.
I ran both an antivirus (ESET) and antispyware (S&D) check with no results, all seems fine. It might have to do with Windows Updates as it installed something. I haven't tried system restore yet but that's the very last resort, any ideas? I'm running Vista (SP1). My left mouse-clicks don't work (in most cases). I must first left click on a button, then hit enter to activate the function. Also, when I try to select items in a drop-down menu, the contents of the menu flashes and then disappears. I must use the scroll button or down-arrow in order to select the menu choices. I also can't select any top menu items with a left mouse click (file, edit, view, tools, help). I must use "alt-f" for file, etc.).
This all occurred after a virus infected my PC. I was able to delete the virus and get most things to function properly, but the mouse-click issue is the final remnant of the infection.
The virus also deleted all of my restore points. You would think that MS would place those in a non-accessible part of the OS kernel that can't be accessed by any common code that's used to create a virus; but noooooo!!!
Anyhow; if anyone has been exposed to this scenario and come across a solution, I'll send you a gift certificate to a restaurant. If you're a cutie, I'll take you there personally!
Please try performing the steps mentioned below;
  1. Right click on the My Computer icon
  2. Click on the option Properties.
  3. Select the tab Hardware.
  4. Click on the button Device Manager
  5. Click on the ‘+’ sign in front of the option “Mice and other pointing devices”.
  6. Double click on the option “HID-Compliant mouse”
  7. Click on the button Update driver.
  8. Restart your computer and check the results.
Posted on Mar 13, 2009
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
My mouse scroller is not working
The above symptom is associated with, but not limited to, the following systems:
  • ThinkCentre M70e, M70z, M71e, M76, M77, M80, M81, M90, M90p, M90z, M91, M91p, Edge 71z, Edge 91z
Applies to:
  • Microsoft Windows 7 in XP Mode
The system is configured with the following:
Windows XP Mode in Windows Virtual PC on a computer that is running Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Lenovo USB mouse driver for Windows 7 (Lenovo Mouse Suite)
Additional Information:
As of writing this tip, Lenovo Mouse Suite Version 6.48 can be downloaded.
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS014888
Lenovo USB mouse driver for Windows 7 (32-bit and 64-bit), Vista (32-bit and 64-bit), and XP.Uninstall Lenovo Mouse Suite.
  1. Click Start, then click Control Panel, View By: Category.
  2. Under Programs, click Uninstall a program.
  3. Right-click Lenovo Mouse Suite, then click Uninstall/Change. You may see a dialog stating, "Windows needs your permission to continue." If you see this dialog, click Continue.
  4. Follow the instruction on the screen to complete the uninstall process.
Other steps.
If you still need some Lenovo Mouse Suite function under Windows 7, the following steps may effective.
  1. Mouse Properties
  2. Select "Lenovo" Tab > Advanced Properties.
  3. Select "Wheel" Tab
  4. Change Wheel setting to "Use Microsoft Office 97 Scrolling Emulation Only" from "Enable Universal Scrolling."
Feb 26, 2013 | Lenovo Computers & Internet
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
How do I double right click if I don't use a mouse, I use a touch pad
Notice how the touchpad is laid out. Normally there is the big square area that you slide your finger across to control the mouse pointer. Then either at the top or at the bottom of the touchpad there will be two separated squares that you can click on. They work just like a mouse. the one on the left is a left click, the one on the right is a right click.
Apr 03, 2012 | Acer Aspire 5720 6497 Laptop
Touch pad and mouse butons don't work at all.
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there’s no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Vista
Go to Control Panel> Mouse> Settings tab of the device
Click <Enable> (or <Disable> to disable)
Please go through this image, will help you..
Notes:
On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
You can click Reset device if neither of those solutions will work. ..
Please revert for further clarification....
Jan 16, 2010 | Acer Aspire One PC Notebook
The mouse on my acer laptop is very sensitive and keeps clicking on things i dont want it to. how can i stop the mouse from clicking on things?
go to Control Panel on the start menu. then find the mouse icon in XP and in Vista look under Hardware and Sound. You should see a window like this and you can set your mouse as you please, good luck.145568b.png
Nov 06, 2009 | Acer Windows Vista TL-562G Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Use system restore I think thats your only solution next to a full format
Jun 28, 2008 | Microsoft Windows XP Professional
Mouse freezes
I had the same problem. The following solution from 3M support fixed it. We Normally see this problem on laptop computers running Windows XP. There is a power management setting in the Device Manager, which controls the USB Root Hub. Often this setting is selected to "allow the computer to turn off this device to save power". When control of the mouse is needed again, the computer is unable to turn the device back on. To remove this power management feature follow the instructions below. 1. Right click on the "My Computer" Icon on your Windows Desktop 2. Select "Properties" from the Menu 3. Click on the "Hardware" tab in the system properties window 4. Click on the "Device Manager" button 5. Click on the (+) plus sign next to "Universal Serial Bus Controller" in the Device Manager 6. Locate the "USB Root Hub" (Note: there may be more than one, and you will need to change all of them), double-click on the "USB Root Hub" to access the properties windows for that device. 7. Click on the "Power Management" tab 8. Remove the checkmark from the box containing the following option "Allow the computer to turn off this device to save power" 9. Click "ok" 10. Close the Device Manager and all other open Windows Test the Mouse to be sure that the new settings are working. You should now be able to leave the mouse unused without it being turned off by the operation system.
Aug 08, 2006 | 3M LX400 Mouse
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
