Question about Woods Upright Freezer MU07W
My woods freezer was working fine i defrosted it and now the motor only runs for a few second and then shuts off help
I have a woods freezer Woods model v15hds . I just got it out of storage yesterday,. I plugged it in and can hear the motor running and the shleves are cool, but it is not freezing. What could it be
Posted on Aug 23, 2010
  • 400 Answers
The starter relay is most likely bad and needs replacing. Rate
Posted on Mar 11, 2009
Freezer coil inside freezer box loads up rhyme ice preventing air flow. If I defrost the freezer it will work fine for a few weeks. I suspect there is a defrost timer, or humidity control that isn't...
There are three parts to all defrost systems.
1. Defrost Heater2. Defrost Timer3. Defrost Thermostat
Without a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
Aug 02, 2011 | Sub-Zero Freezers
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Nov 22, 2010 | Woods Freezers
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
Ice builds up in the freezer
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Woods Upright Frost Free Freezer
its just the machine defrosting itself, let it wee until its empty, then switch back on and let it settle for 24hours before loading up with beer etc......
May 27, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Woods Upright Freezer MU07W Logo
737 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal De
Are you a Woods Freezer Expert? Answer questions, earn points and help others
