Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer and refrigerator not cooling.
Compressor comes on every 5 minutes or so, runs for 5 seconds and then cuts off.
  • 400 Answers
Are you sure that the compressor actually runs, if it does start up and run, I would suspect a blockage in the refrigerant tubing around the filter drier where it is reduced to capillary tubing. If the compressor is just trying to come on, then switching of, I would try changing the starter relay first.
Posted on Mar 11, 2009
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Maytag MZD2766GES refrigerator quit cooling, both sides. Noticed frosting on freezer contents, and next day the ice maker ice was melting and running on the floor. We can hear a clicking every 5-10 minutes...
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Remove the cardboard backing from the back bottom to access the compressor area.
Dec 20, 2009 | Maytag MZD2766GES Side by Side...
My haier 5.0 chest freezer model # hcm050eb has quit cooling. When I checked the compressor I hear it come on for about 3-5 seconds and then it shuts off for a minute before repeating this. I've unplugged...
your freezer is short cycling which is bad for the compressor. Usually there is an internal overload in the compressor that automatically resets as the compressor cools. Check to see that all of the coils are clean and the small fan is blowing. this will make sure that the airflow correct. look for signs of oil around the compressor, the coils, and any connecting tubing. if you find oil, this is a sign of refrigerant leaks. the refrigerant is what cools the compressor and it wont run long in an overheated condition. it will finally fail in the open position and not come back on.(compressor overload switch) If this is the case you may replace it cheaper
Nov 21, 2009 | Freezers
I have a freezer chest the compressor comes on but it never cools
Nov 10, 2009 | Kenmore 8.8 cu. ft. / 249 liter Chest...
So-low freezer try to start, but stops after a second
How to check stuff>
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
133 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
