Question about NEC Office Equipment & Supplies
NURIT 2085 (i cant figure out the passcode)
My last manager set this machine up for my business and he knew the passcode. Well, i unplugged it and it asks me for the code before i do anything. does anyone know how to reset this code so i can use the machine???
At the password prompt, if you press the alpha key you can get the date the terminal thinks it is. use that. Sometimes some terminals are wrongly programmed therefore the internal clock may be off, setting the password off.
Posted on Jul 30, 2009
  • gallencarsto Jan 19, 2011
    Worked like a charm! Thanks!
  • 18 Answers
Try unplugging the power, then hold down the one, five, nine, and review keys. While holding down the keys plug the power in. when the power is back up it should say 1. Back to NOS, press enter then it should say 1. Run Appl, press enter. then you should get the main screen Credit Sale Account. If not try these passwords using the date format either DD/MM or DD/MM/YYYY as long as the date is correct.
Posted on Mar 26, 2009
Mine was MMDDYYYY same as the alpha date screen - thanks exofo and steve627!
Posted on Mar 07, 2010
Nurit 8020 - Change NOS - Remove SECURE
If you are just reloading a NOS in your Nurit 8020 machine, even if your machine is secured you should be able to load it, make sure your com1 baud rate setting is the same, your 8020 is set to 115200 baud rate, and should set up your com1 at the same speed...hope this will help and if you still need more help you can call us at (775)358-2922 ask for Randy. Thanks
Jan 03, 2012 | VeriFone (M19755014US1) Magnetic Card...
My Nurit 2085 "Enter" button is becoming harder
The enter button is getting harder do press because the contacts below the button are getting worn. The only maintenance that you can do is to take the machine apart and clean the contacts. This will make it like brand new. And you should blow out the buttons with canned air every couple of weeks, for future reference.
Nov 30, 2010 | Office Equipment & Supplies
Anyone have any info on how i can update my Nurit 2085 from NOS 6 to NOS 7 I have heard that Verifone no longer supports the update.
VeriFone NOS 6 Operating System
VeriFone has assigned “end of life” status to the NURIT NOS 6 operating system. The terminal manufacturer previously announced that it would discontinue support for NOS 6 applications and stop offering NOS 6-to-NOS 7 upgrades on October 31, 2009.
On July 1, 2010, VeriFone will permanently shut down the loader required to convert from NOS 6 to NOS 7, making the upgrade unavailable to all models of NURIT terminals.
Merchants who wish to continue receiving support for impacted NURIT terminals are strongly encouraged to update their operating systems (if possible) prior to the July 1 deadline. Currently, there are three devices in the marketplace that may be eligible for the NOS 6-to-NOS 7 operating system upgrade:
  • NURIT 2085 03
  • NURIT 2085 04
  • NURIT 2085 21
To notify eligible First Data Independent Sales customers, they will include a message in the May 2010 month-end merchant statement (scheduled for release in early June) advising NURIT 2085 users to contact the Omaha POS Help Desk to update their terminals.
To do the same call on:866-783-8380
Jul 25, 2010 | VeriFone (M19755014US1) Magnetic Card...
Can anyone tell me why my nurit 2085 doesnt display the "credit......sale, account?" It just displays "prepaid enter/swipe" is it because I dont have a merchant account yet??
"That could be it.
You have to have an account active with a Bank and confirmed to get proper access via the POS terminal.
Contact you VeriFone customer support. For proper setup.
Apr 15, 2010 | VeriFone (M19755014US1) Magnetic Card...
Nurit 2085 says it can't run appl
Have the processor rebuild the file for your machine. If there is some corrupt data in the file build it can cause issues. Before redownloading the new file be sure the processor wipes memory fully on the terminal so none of the old data remains. After the redownload, you will know if it was a problem with the original file, or a hardware issue. If you want to use another cc service, contact us at premieramericard (dot) com.
Best of luck!
Aug 24, 2009 | VeriFone (M19755014US1) Magnetic Card...
THE BEEPING ON THE NURIT 2085 MACHINE IS TOO LOUD CAN I TURN THAT DOWN
Easy fix. Hit (Menu/Esc), Scroll down to #3 (Merch Options), Enter, Scroll Down to #3 (Buzzer Set), Enter, Press #1 (Off). The annoying beeping should go away.
Apr 07, 2009 | VeriFone (M19755014US1) Magnetic Card...
Nurit 2085
Is the pin pad plugged into the port marked pin or the port looks like a small pin pad? Th most important thing is do not unplug the pin pad while the terminal is on you risk the chance of loosing the encryption the pin pad has programmed into it. If this happens you will need your processing company to re encrypt the pin pad. Turn the terminal of make sure all connections are nice and tight power back on. If no luck call your processing company.
Mar 04, 2009 | VeriFone (M19755014US1) Magnetic Card...
My nurit 2085 has stopped printing a second receipt after transaction is completed. I must have changed something while cleaning it. how can i have it print a second receipt?
Press the yellow menu/esc key (enter password if app.) press 3 and select single ply paper from the menu (use the arrow keys to navigate ie. return, void, verify, offline) then esc to the main screen.
Nov 25, 2008 | Office Equipment & Supplies
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
3,748 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
