Question about Refrigerators
I have a roper refrig and the model number is RT18BKXJW00. My fridge part is ok but my freezer will not freeze stuff. I do not see a knob that will turn it up or down. just one in the lower half for just the fridge part.
  • 400 Answers
Only the fridge has a control knob. You should check in the freezer compartment, if the back wall is frozen you will have reduced airflow through the cabinet and later even to the fridge. I would have the defrost system checked out.
Posted on Mar 11, 2009
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Nov 23, 2014 | Frigidaire FPHS2386L Stainless Steel...
Refrigator with a top freezer freezes up about every 4 weeks
Check the door and seals, does it close and seal properly.
If the seals are letting in warm air, the fridge goes into overtime, hence freezing up.
Its also worth checking that the fridge isn't on too higher setting.
May 10, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer is over freezing/ice-ing up behind the board {where all the wires/fans/stuff is} thus not keeping fridge or freezer as cold as it should be.
You fridge has a broken defrost controller or a broken heating element.
Go to Roper online to find your parts and then see if you can buy them either at applianceparts.com or ebay. These are good cheap ways to get your stuff sent directly to you!
Then, unplug the fridge, thaw it out. And while its unpowered and thawing replace the two parts. Refer to your units parts diagram for parts locations. The controller should just be hiding down underneath or in back and the defroster heating element is usually under the freezer.
Good luck and be careful!
Feb 08, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Mod#RS25AGXN002 FRIG NOT COOLING FREEZER NOT FREEZING
the return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Oct 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer freezes but refrigator not cold
your fan between the freezer and fridge is out. This fan allows the cooling from the freezer to cool your fridge section. This fan is located between the freezer and the fridge in the area of the temp control knob in the fridge. This area should be able to be accessed by pulling the screws that holds the assembly to the top inner part of the fridge. Once this part is removed you can see the fan. Take the model and serial number to the appliance parts store for correct replacement part. Understand that this is a 7 in difficulty on a scale of 1 to 10 to replace so if you feel like it you can repair it yourself however a tech could do it must faster at least you know what is wrong. Good Luck hope this helps on your repair
Dave
Sep 02, 2009 | Refrigerators
I don't know how to shut my freezer off to defrost it
you can turn the temperature dial to zero or you can unplug it. dont worry about warming up beverages but perishable from your fridge into a cooler
Aug 22, 2009 | Freezers
Roper Freezer Stopped Freezing
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
