Question about Elektra Microcasa S1 Coffee Maker, Espresso Machine
Elektra Microcasa a leva
I have a Elektra Microcasa a leva that hasn't been used in about 25 years . It was bought in Italy and has a 220 plug. The underside has a panel that says it is 220 v 50 H 800 W...Could this be right? Can I use it and can I get parts? Do I need a power adapter? What would I need to get it in working condition.
  • 8,596 Answers
You will need a 120/220V transformer for starters. That will make the Italian coffeemaker compatible with American outlets. The good news is that you can't do harm by plugging a 220 into an American outlet - it will just not give you enough power to run the machine.
I doubt that you can still get parts - I've seen used ones that still work on sale for anywhere from $1,000 to $3,000 - not cheap.
Here is all the contact info for Elektra - they are definitely still in business:
Elektra s.r.l. - Italian Espresso Coffee Machines
Via A. Volta 18, 31030 Dosson di Casier (Treviso) Italy - Tel +39 0422 490405 - Fax +39 0422 490620
Url: www.elektrasrl.com - Contact: info@elektrasrl.com -
Posted on Mar 11, 2009
I'm going to Italy. Is it dual voltage?
Italy uses 220 volts, 50 cycles alternating current (AC). If your appliance works on both 110 or 220 then IT'S dual voltage and should work. If it only runs on 110 then you will need a voltage converter to use it on 220.
Dec 03, 2015 | Wahl 8081
Wife turned on machine with low water. Lights are on but does not heat up. Reset button does not
There is a thermostat reset switch that is accessible through a hole in the underside black plastic base. You can use a screwdriver to poke through the hole and depress a cylindrical push button switch. Please unplug machine and remove parts that fall off before tipping it over.
Mar 12, 2012 | Elektra micro casa a leva S1CO Espresso...
I live in Helsinki and have a great Elektra SX I bought in Italy in 1993; it has worked well for 18 years. Today, both pumps work--water flows to the coffee cup area and also flows through the side...
Hello, Lucas -
I have not found any kind of repair or replacement part information (for Finland) regarding Elektra coffee and espresso machines. It seems they manufacture their machines to last a long time and keep tight control on repair.
I am answering from the USA and am having difficulty in finding a repair center for you in Finland.
Therefore, I suggest you contact the Elektra company directly. This is the link to the Elektra home page:
http://www.elektrasrl.com/en/company/
If you scroll to the bottom of the page, you will see an email address (in the lower left corner) you can use to send a message asking about repair service to your machine.
Best wishes.
Mar 03, 2018 | Elektra (SX) Espresso Machine & Coffee...
Pfaff210 sewing machine foot pedal
google the manufacturer and see if you can get one by mail from ITALY
Dec 11, 2009 | PfaFF Sewing Machines
Replacing orings on glass level indicator
Not hard to do. Unplug and drain the water. unscrew the frothing wand and tip the machine gently over a sink to drain the water in the system. Then using a box wrench (don't use an adjustable wrench or poorly fitting tool) remove the water reservoir. THen you can unscrew the pressure gauge easily. At that point, the glass is exposed. Gently twist until it's free and pull the glass up and out. When you are replacing the white Orings, a small bit of olive oil on the inside will help you insert the glass back into the orings. Then replace all the components.
Apr 13, 2009 | Elektra Microcasa S1 Coffee Maker,...
I'm looking for Elektra S1 Owner.s manual
if you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
  1. the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
  2. if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
Nov 23, 2008 | Elektra Microcasa S1 Coffee Maker,...
Elektra Microcasa Semiautomatic
clear the connections of glass with boiler. change glass seals. (be careful not to brake sight glass tube)
Nov 09, 2008 | Elektra micro casa a leva S1CO Espresso...
Work in Europe?
According to the rear panel of my 2200, it will accept 120VAC 50 ~ 60 HZ. Which means that outside of a proper plug adaptor, it should work fine. You need to adapt the epson power cable to whatever the French use. Be sure it is 110~120 VAC. Ran into some 220 in Italy
May 26, 2008 | Epson Stylus 2200 InkJet Photo Printer
Power light on, no warning light, doesn't heat up at all
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Jan 04, 2008 | Elektra micro casa a leva S1CO Espresso...
Elektra KPGC 100NP
Nov 18, 2007 | Elektra micro casa a leva S1CO Espresso...
Elektra Microcasa S1 Coffee Maker, Espresso Machine Logo
261 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
vilhj
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
