Question about Dishwashers
Bosch SHU9952 dishwasher drain pump never stops running at end of cycle or when door is open. Also, no fresh water enters after restart.
  • patkendavido Mar 11, 2009
    Pump drains the water fine, it just doesn't ever stop running.
    Re. Solution #1 "If the water doesn't drain from your dishwasher, check these:"
    Referenced solution doesn't address the problem, i.e. Bosch SHU9952 dishwasher drain pump never stops running at end of cycle or when door is open. Also, no fresh water enters after restart.
    Genius:
  • 1,239 Answers
HI
Check the hoses for kinks. Make sure that water is getting to the water intake hose. With your tap shut off, loosen or remove the hose from the tap, then open the tap slightly to see if water is getting to the hose intake. If water is getting to the hose, remove the hose from the washer to see if water is making it through the hose to the water intake valve.
Make sure the lid is down as some washers will not fill if the lid switch is not activated. Also, make sure the drain standpipe is at least 30" tall. If it isn't, the water may get siphoned out of the washer. If this is happening, install an air gap in the drain line.
Posted on Mar 11, 2009
  • ABHISHEK.C
    ABHISHEK.C Mar 11, 2009
    Adjust the temperature setting to warm and set your timer to the fill cycle. Start your washer and lift the lid. You'll want to depress the lid switch with a screwdriver or other tool to prevent the interlock from engaging during this test. Feel or look for water entering the wash tub. If no water is coming in, or if it is too hot or cold, you'll need to test the voltage on each solenoid valve with a volt ohm meter or Digital VOM. The voltage should be between the ranges of 110v to 125v.
    If the voltage is correct and the valve is not opening, you need to replace this valve. If the valve is not getting any power to it, you will need to use your washer specific wiring diagram to look for any broken wires, and if there are no broken wires, move on to test the lid switch, temperature switch, timer, and the water level switch. Replace anything that is defective.
    President:
  • 987 Answers
Http://www.applianceaid.com/boschDW.html
this link might be helpful
    Scholar:
  • 164 Answers
Hello there
Sounds like your impellor is blocked. Depending on the model you have, if you remove the filters you will see a small hex screw in the sump, undo this screw & remove the small cover, this will expose the impellor of the pump see if any foreign objects are jamming it, this method should be in your instruction book.
again depending on the model of your machine h ave a look into the bowl at the bottom. If there is a cover held by a screw on the left side, take the screw out, remove the cover and check for some debris blocking the impellor. Be careful as glass is the most common item found in the impellor.
Good Luck and please don't forget to rate on Fixys.
Thanks
  • 1,800 Answers
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
  • 790 Answers
Hi
maybe you have shorted auto switch, this switch needs to cleaning
Thanks!
  • 10,515 Answers
Check your installation. Most likely the drain hose has not been installed with a high loop.This is the most common mistake I see with Bosch dishwashers.
You may want to search GW for High Loop to get more info on how to correct your problem
  • taran_2005
    taran_2005 Mar 11, 2009
    Hiya,
    There is water in the base activating the anti flood device.
    Unplug the appliance from the wall socket.
    Take off the inspection panel from below the door and use a sponge to empty the base.
    Once it's empty the anti flood will reset and the machine should work again.
    If still having problems you'll need to take the machine out and take off the left hand side panel (when viewed from the front) and check that the red lever has reset.
    If it starts then faults quite quickly then it's likely you have a leak. You'll need both side panels off to watch and see where it's leaking from.
    (If it's a freestanding machine you can pull it out and try tipping it backward about 45 degrees to drain the base)
    Hope this helps
    Thanks
  • 583 Answers
Check if the control panel button stuck up .also check if anything is stuck up inside causing it to fail
    Sergeant:
  • 300 Answers
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch Clasixx dishwasher sticks at point when it drains water
you have a clog remove the float clean and replacs,sould work now.
Jul 15, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
