Question about Apple iMac OS 9.1
I can't open my applications from the desktop or anywhere else.
I had lost my applications folder from under the apple. There was a message that was on the screen saying to check to see if my dry.l was in my stf folder. It was but it was empty. How can I find my applications?
  • 527 Answers
Reinstall that software it will worked
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 11, 2009
  • Asfiya Ahamed
    Asfiya Ahamed Mar 11, 2009
    If you don't have that application let me know i will send you a free download link.
    Good Luck
Why can't i install whatsapp on my mac
Apple has restricted your ability to install any app, they want to control the apps you put on so that they only come from their Mac App Store.
However there is a setting under the apple menu: System Preferences: Security & Privacy where it lets you choose (with a button) to allow applications downloaded from Anywhere, which if selected will allow you install Apps not found on the Mac App Store.
Aug 10, 2014 | Apple MacBookPro 15-inch 2.16GHz 120GB...
Can't open my iTunes when open get error messages ""Apple application support was not found." Apple application support is required to run iTunes.
I think you have not follow the basic rule. first check your system configuration with iTunes application requirement.
If possible update your system. Now you can download a Apple Application Support file and if not helpful then read this tutorial if you have some technical knowledge
and follow Mac Technical Support for more guidance.
Jul 30, 2014 | Apple iTunes
System preferences wont open on my i mac how can i fix this
Have you tried to open up the system preferences either under the apple menu or going to the applications folder and opening the system preferences from there. If it is not in the applications folder do a search for system preferences and see where it is located and drag it into the applications folder. Hope this helps.
Jan 03, 2013 | Computers & Internet
Scanner not working
Re-install the Scanner software.
Sep 08, 2012 | Canon PIXMA MX860 All-In-One InkJet...
I am having trouble opening up my Mac without using the Safe Mode. I also have no volume and cannot fix it The sound area is greyed out and I cannot change the settings. It says I have no device in or...
Click anywhere on the desktop (not a window) and press command (apple) and "N",
1. Open the Applications folder.
2. Open the Utilities folder.
3. Launch Audio MIDI Setup. It will give you some options to configure your sound input and output devices. Once you make the changes and close it, you should have sound again.
Sep 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Internet crashing- what's the problem/ solution?
Sometimes for what seems to be a very difficult issue, can in fact have a simple solution.
These browsers have preferences lists in their directories which if corrupted adversely impact the functionality of these web browser applications, so try these steps:
font.f1 {font: 12.0px Helvetica} • From your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Home from the
drop-down menu. This will take you to your Home folder.
• Locate and open the Library folder
• Within Library folder look for the Preferences folder and open it.
• Locate and remove to the Trash, these files:
Once you have removed these files to the Trash, click the back button on the open Finder window.
• This will return you back to the Library view where you now will need to locate and remove to the Trash, the folder entitled "Caches".
*Once that folder is removed to the Trash, close all applications and open windows.
* Next, click on the Apple menu icon (upper left corner of your screen) and select from the drop down window, Logout<username>. This will take you the main login window. Simply log back in to your current user account.
* Before testing your Safari and Firefox browsers, perform one more procedure in order to repair folder/file permissions.
font.f1 {font: 13.0px Myriad Pro} -RUN DISK UTILITY FIRST-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed
this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utility run this repair permissions process, until completion.
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run DU to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Once this is completed, now you should relaunch
both Safari and Firefox to see if they will now launch.
Update me if these processes did not help.
Jan 29, 2010 | Apple MacBookPro 15-inch 2.16GHz 120GB...
Problem opening quarkxpress on g4 mac
The first place to look is your permissions. Open your utilities folder in your applications folder and launch **** utility. Click on your hard drive icon and click the repair disk permissions button. It may take a few moments to run. That might solve your problem.
If that does not solve the problem. Open library/preferences/Quark. Move the pref' doc in that folder onto you desktop (don't trash yet) try relaunching the app. If still not working trash the pref' and try again.
If all that fails I'm afraid you'll have to re-install the app'
Sep 28, 2008 | Apple iMac G4 Desktop
Microsoft office
If Mac Office is installed, you can find your Mac Office by clicking on the hard drive, click on application folder then scroll down till you find it. Once you find it , open the folder , thenyou can drag Word,Excel,Entourage to your desktop and make an alias icon.
Sep 26, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iMac OS 9.1 Logo
277 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
