Question about Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K
Table saw capacitor heats up and explodes.
I have a powermatic table saw. When i turn the saw on the capacitor on the motor get real hot and blows its end off. What would cause this?
    Problem Solver:
  • 9 Answers
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Posted on Apr 04, 2010
Table saw won't start
You can only tell by using a continuity tester or a multimeter and some troubleshooting techniques.
Nov 10, 2013 | Powermatic 1791227K Model 64 10" Artisan...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have powermatic pm2000 3hp 10" saw, when I try to turn on push on button , it blows the breaker. I have correct power. I have used this saw for 5 years no problems. I took magnetic switch apart,...
There is a direct short some where.Unplug and turn the blade and listen to the bearings. One of the brushes might be worn down and be jammed against the armature. Five years of use and those brushes might be ready for replacement. If things turn out to be easy fix then changing brushes is not that hard.When you take them out you will see some small holes in the holders.When you put the new brush in the spring will try to push the brush back out,use a small piece of wire in the holes to hold it in.Next install the brushes back where they go.Check the armature out use a hacksaw blade to clean those grooves between the metal strips.Put the armature back in place and button it back together and pull out the keeper wires and your done.
May 08, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a powermatic table saw, 7 years old with a 2 hp baldor motor and when i start it the motor hums but the blade just shakes back and forth. I can turn the blade by hand and rotate the motor fan...
You may have lost power on one of the wires to the motor. Check the wiring for breaks, if you have a meter make sure there is power to the 2 110 volt wires.
Jan 09, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Our Powermatic PM66 will not start... the motor will run if the contacts are manually engaged but the contacts will not pull in using the start switch
If the motor runs without the switch then the problem is the switch. Pull out and blow it clean of sawdust and try again. Also check the connections at the switch to make sure they are tight.Hook a meter up and turn the switch on to check for continuity. Remember, switches wear out also and need to be replaced.
Oct 14, 2009 | Powermatic 1660802K Model 66 Special...
Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Aug 16, 2009 | Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
My Powermatic 66 table saw won't start. Tried to turn on my Powermatic 66 table saw this morning. Blade moved one half inch as if trying to start. Tried reset button on motor, still nothing.  I...
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Jun 08, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K Logo
390 people viewed this question
Top Powermatic Saws Experts
80stech
Dennis Key
Dennis Key
Ivan
Ivan
Level 1 Expert
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
