Question about Canon Pixma MP800 All-In-One InkJet Printer
Problem Code: 155,0,0
HI, I get a message that says ' CANNOT COMMUNICATE WITH SCANNER. SCANNER MAYBE TURNED OFF OR A CABLE MAYBE DISCONNECTED. PLEASE CHECK THE STATUS AND TRY AGAIN. SCANNER DRIVER WILL CLOSE.'
CODE 155,0,0
I have checked all cables and they are connected correctly. The scanner starts to scan then stops and I get the above message. Please, can you help.
Regards Sandra
  • 46 Answers
SOURCE: scanner error
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Posted on Sep 24, 2007
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Posted on Apr 05, 2008
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Posted on Mar 09, 2009
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
My printer show this code 2 E 7
I have problem with my scanner.
when I want scan whith that show this message:
cannot communicate with scanner
cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550
please help
Jun 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I cannot get my PIXMA MP140 to scan anything. I've tried re-installing the software and downloading the latest drivers. Nothing helps. It prints just fine. I get the following message each time I...
1. install alien Symaptic Package Managerunder System, Administration.
2. Go to HTTP://www.canon.com, Support and get the 4 required Linux Drivers. cuijfilter common and cuijfilter MP140 series, scangearmp common and scangearmp 140 series drivers. Download them to your desktop. Get the .rpm version only for this to work.
3. These files are in the .rpm format and they need to be converted to .deb.
4. use the terminal window. cd ~/Desktop. That will put you in the desktop.
5. Convert the files to .deb by using sudo alien --scripts scangearmp-common-1.10-1.i386.rpm and sudo alien --scripts cuijfilter-common-2.80-0.i386.rpm. These are only examples and you need to be exact or it will not work.
6. Double Click the .deb files and they will be installed. Install the common files first then the 140 series next.
7. Reboot the computer and the scanner will show up in the GIMP Image Editor, File, Qcquire, Scangearmp.
8. You then need to go to System, Administration, Printing and configure the MP 145. It is called the MP 140 series and Make and model is a Canon PIXMA MP150 CUPS ..........
Apr 23, 2008 | Office Equipment & Supplies
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
4,590 people viewed this question
old marine
old marine
