Question about LG LHD65EBL Dehumidifier
Chlorine added to a dehumidifier
My mom was told to ad chlorine bleach to the dehumidifier in her bedroom. It makes my eyes water as is circulated throughout the house.
Was she told correctly. She tells me the manufacturer instructed this.
    Guru:
  • 462 Answers
NOT the best suggestion Ive herd.
1st Chlorine is very corrosive to copper and aluminum.
2 In strong concentrations like your describing it is unhealthy. Usually 1 or 2 teaspoons per quart is plenty to sanitize the air and wont cause you health problems. And If you use more than this it needs to be followed by a manual rinse and wash out.
Posted on Apr 30, 2009
Red exclamation sign blinking
Dehumidifier? Sounds like a warning of some sort. A humidifier does a simple job, removing moisture from the air. If yours is not set up to drain, it could have a full holding tank. Empty it out and give it a rinse and it should be good. Drop a couple drops of chlorine bleach in it to keep down the mold growth.
If it isn't a full tank, it could be an air filter that needs cleaning or replacing. Often these things are programmed in and needs to be cleared. Clean and or replace any and all air filters and look for a reset button.
Good luck.
Mar 15, 2014 | Dehumidifiers
After refilling and waiting the 2 minutes...turned it on but it would not heat the water or make any mist
Some water will not produce mist unless something is added to increase mineral content. Your instructions should mention this
Jan 04, 2013 | Sunbeam Warm Mist Humidifier Dehumidifier
Coils on the dehimidifier are dirty resricting air flow how do I get ti apart to clean the coils
Make sure you unplug the unit first. there should be screws at the base, in the back, or underneath the humidifier. Once you remove all the screws the cover should come off as one big piece. Careful when removing the cover, however, as there may be ground wires attached to it . Usually if you vacuum out the inside godd and around the copils that may help with performance. You can also buy a special acid that you can spray on and rinse off with water that removes alot of residue.
http://www.iallergy.com/product841/product_info.html
Also, Don't forget to pull the plug, shut the water valve and drain the unit. A unit with a water reservoir should be drained and cleaned with white vinegar, a mix of one part chlorine bleach to eight parts water or muriatic acid. Mist-type humidifiers also require regular cleaning to remove mineral deposits.
Mar 30, 2011 | Goldstar DH504EL Dehumidifier
I have had a m old problem in my apt. how can I keep the mold from growing in the dehumidifier? bonita
One thing that I have had good results with on controling mold and bacterial build up is to add a couple of ounces of chlorine bleach every month. You can purchase commercial products to do the same thing at most hvac supply stores. They do smell much better but are not cheap. Hope this helps you. Thanks
Jan 25, 2011 | Comfort-Aire BHD-301 Dehumidifier
My dehumidifier (new air AD 400, 6 months old) stopped working. Fan blows, humidity level is indicated, motor gets hot, but no water comes out. I tried unplugging, resetting, etc to no avail.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 18, 2010 | NewAir AD400 Dehumidifier
Whirlpool dehumidifier does remove water
indicates a gas leak and there is insufficient gas in the system
Oct 19, 2017 | Whirlpool AD50USS Dehumidifier
Dehumidifier (challenge 12ltr) gives off a smell a nasty when running.
Clean the filters and the coil. Use a mild bleach solution if there is mold present.
Oct 03, 2009 | Dehumidifiers
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Out of the ground pool-hayward sand filter
This one is easy...
You simply fill your pool to the normal level which is at the top of the skimmer.
Now apply the "Shock" treatment to begin clearing the water.
With the pool full, attach the hose for back flushing to the filter 'Outlet" or discharge side and then move the selector handle to the "backwash" position and turn the pump on. It will begin discharging water out of the hose. Run it this way until it begins sucking air.
You have now "backwashed" your filter.
Fill the pool back to the normal level and finish treating water to get the Ph and Chlorine right.
Enjoy swimming.
Jun 01, 2008 | Dehumidifiers
LG LHD65EBL Dehumidifier Logo
272 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
