Question about GE DBXR463EBWW Electric Dryer
GE DX4500EG6WW FROM SAM'S WILL NOT DRY CLOTHES WELL. This is the same as DBR463EGWW model.
  • GE Master
  • 5,568 Answers
Try using the manual settings instead of automatic; the thermostats responsible for checking humidity may be faulty. If you can get dry clothes this way, then you have an idea what has failed.
Posted on Mar 11, 2009
  • fldreamin2 Sep 07, 2011
    This worked for our dryer!! I almost went out and bought a new dryer too. Thank you for saving us the cost of a new dryer!
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
The dial on the GE dryer does not move. but clothes dry
the dial on my ge dryer does not move, but clothes dry
Aug 03, 2009 | GE DVLR223 Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
370 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
