Question about Dell Inspiron 1000 Notebook
I posted a question about my Dell computer. The prong that connects to the elect. has broken off inside the computer. Can I fix that? Can I melt the plastic back together and attach it to the motherboard. I have the thing apart all the way to the motherboard.
  • snowlake Mar 11, 2009
    let me wait till tomorrow and I will get to it.. I really need some help. I will take a picture and send it to you how do I do this.?? let me know.
  • snowlake Apr 19, 2009
    I am really scared to use the soldering iron on the computer. not that good with it.. I wish someone else could help me with an solution to this .. maybe I just need to take it to someone who can order a piece that they can solder into the motherboard.. what do you think..??
  • 583 Answers
Yes u can try such things but there is always a risk u might spoil something else so plse take enough care while doin it.or else tale technicians help.
Posted on Mar 11, 2009
  • 6,784 Answers
I wouldn't recommend this at all. if you are good with a soldering iron and solder, this would be best.
  • Dell Master
  • 13,433 Answers
Could you take a picture for us?
  • 4 more comments
  • Ekse Mar 11, 2009
    You can email me at nikoht@gmail.com
  • Ekse Mar 12, 2009
    Let me know when you have emailed the picture to me, just to make sure it doesn't get stuck in spam or anything else.
    Thanks.
    Generally you can't melt the broken part of the board back together. but we might be able to wire the power connector or fix it if its just that, if a bigger part broke of the board we may not be albe to fix this.
  • Ekse Mar 13, 2009
    So things that you will need.
    1. Soldering iron and related a multimeter is recommended
    2. Some wire
    3. Connectors for the ends of the wires that will be outside the laptop.for example you could get your hands on a male molex and
    a female molex connector. pictures below.
    There are many other possible connectors, just make sure it has 2 connectors that cant be accidentally wired the wrong way.
    You only need two wires from the 4. so take the yellow and red wire for example, or yellow and the other black, doesn't matter that much. Take the ones you prefer and cut the other two off from the connector.
    do this on both plugs and make sure when you attach them together that you didn't cut the wrong wires.
    now you have the connectors ready.
    4. Identify the + and - on the charger. It reads on the bottom I found a general picture of the charger used with your dell. I can see that the outside is - and the inside is +.
    But we can't really use the round connecor here. So you could cut the connector off from the charger, then cut some cover of the wires so you can get to the wire inside. Here you can use a multimeter to check which wire is + and which is - (dont let the wires touch if you plug the charger to the wall, if those two touch long enought it could blow the charger.) So if you put the multimeter on 20v or higher. DC, then plug the charger to the wall and use the multimeter to test which wire is + and - todo this just plug the multimeter red wire to the other wire and black wire to the other, if the display shows the voltage with a - infron(example -19v)then the two wires are wired as in reverse. so if you swap the red and black connector on the multimeter it will show 19v now you know which one is positive and which one is negative.
    Wire them to the male molex connector red to the positive and yellow or black to the negative.
    We are half done.
    Next take two wires and wire them to the female molex connector on the appropriate slots so that they match with the other connector and that you get + on the red and minus on the black or yellow, now you should be able to connect the two molexes together and the wires should match and if you use a multimeter you should get the same voltage from the right wires, red + and black/yellow as - minus, it should show the same 19v if it show with a minus infront -19v are you sure you wired the + and - correctly? possibly they are the wrong way around.
    Last step is to solder the two wires into the laptop motherboard.
    looking at the picture if the charger I was able to find out that the outside was minus and the inside was plus (please confirm this in the bottom of your charger you will have a picture like this, similiar, black and white that has - on the other and + on the other, this should be also in the bottom of your laptop, double check it before you make a solder)
    If the inside is plus and the outside is minus.
    look at the motherboard and the connector, see where the inside was connected to the motherboard, if that is plus then solder the red wire there, then find where the outside connector goes on the motherboard, that will be where you solder the minus -black/yellow wire.
    That is one way of fixing this problem, there are multiple ways, and if you don't feel that you can do this, I would suggest to get some assistance. The laptop wont like it if the wires are wired the wrong way or touch the wrong spots on the motherboard.
    instead of a connector you could use some plugs on the two wires.
    Or you could try melting the old connector back into the slot but that may be difficult.
    I'm still available via email if you need more help.
  • Ekse Mar 13, 2009
    I hope this made sense to you? I was lucky and I learned the basics when I was very young Thanks goes to my father. so this comes very naturally for me.
  • Ekse Mar 13, 2009
    Also ofcourse you could get a new connector for the motherboard and solder it in place. I'm not sure where to get another connector for it but I would suggest to look around
    www.pchub.com
    www.ebay.com for power plugs etc.
  • Ekse Apr 19, 2009
    You can take the laptop to a local tv or video repairer they can do the solder job for you, they might also be able to order the connector for you.
    Try calling around local repair shops and see if they can do it for you.
Power switch melting post rite off
This is not good . IT can lead to fire hazard. If you are under warranty contact them immediately. If you are not under warranty, I need to know what the make and model number is.
Oct 13, 2016 | Refrigerators
Ac cord metal prongs broken
The "prongs" are part of the ac connector assembly. Your TV will require some disassembly to replace the part.
Jan 05, 2014 | Philips 50PL9126D/37B 50" DLP TV
N214 has been dropped on charge connector how can i fix it?
I have a '56 Chevy truck, that I need the torque specifications for the cylinder heads, on the engine.
See the problem? I didn't state what engine is used.
The n214 designation you stated comes up with either Gateway NV53A N214, or Gateway NV55C N214.
This means to me I am looking for a Service Manual for a Gateway NV53 series of Notebook PC, or a Gateway NV55 series of Notebook PC.
1) http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
2) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go down to the line that starts with - Gateway 400. (400 in blue)
Drop down to the second line, (EC54), and scroll across to NV53, in blue.
Left-click on NV53.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (NV53) it may take up to 30 seconds, before the first page comes up.
(First page is black)
IF, I am correct so far as to the model, this is the information you need.
ALSO;
A) Be SURE to buy, and wear an ESD wrist strap. (Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components, inside a computer.
Connect the alligator clip to a good ground source.
(I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If the table you are working on has metal legs, connect to an unpainted surface on one of the legs.
Or at least connect to a large metallic object you can set on the table.
Perhaps a large metal serving tray, or large metal knickknack. (Unpainted)
B) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
(If no multi-compartment container is available, you can substitute with a clean egg carton.
Label each egg holder)
There are MANY screws that look VERY similar to other screws.
DO NOT mix them up.
C) Make a record as you disassemble.
Make notes, and drawings. (Legible so you can read them later)
Use a digital camera, and/or a video camera, if available.
Nice to have a personal record to refer back to, in case you are interrupted.
D) Page 92 in the Service Manual starts with replacing the System Board. (Motherboard)
The motherboard needs to be removed, and in your hands.
E) This is an example of the DC Power Jack,
http://www.machinaelectronics.com/store/buypart/Gateway_NV53/PC-P006
Click on the photo to the left to enlarge.
The view on the left shows the jack in it's normal position.
The middle view, and right view, show the jack upside down.
Looking at the middle view note the prongs ('Pins') sticking up.
The prong at the back, that is in the middle, and has a round shape at the bottom, is for the Positive connection.
The two shiny prongs that are together, and to the left of the Positive prong, are Negative prongs.
The jack has a metal U-shape, going over the top of it's black plastic body.
There are 3 prongs that stick up from it.
These are just used to help anchor the jack to the motherboard.
All of these prongs go through the motherboard, and are soldered to the motherboard.
My style is to use;
1) 25 Watt soldering iron, with a No.2 chisel tip.
(Soldering stand with damp sponge in base)
[Unless I break out the soldering station]
2) .032 Rosin core solder.
3) Desoldering Braid. (Solder Wick)
(Throw all Desoldering Tools {Solder S-ucker Tool} in the trash, as far as I'm concerned )
ESD wrist ********, and connected to a good ground source.
Motherboard on table, and upside down.
Unroll a little bit of the Desoldering Braid.
http://www.radioshack.com/product/index.jsp?productId=2062744
(Desoldering Braid is essentially a bunch of very fine copper wires, woven into a braid. The braid soaks up melted solder)
Place the tip of the braid, on top of one of the solder joints, (Of a prong of the DC Power Jack)
Place the chisel tip of the soldering iron ON the braid, on top of the solder joint.
As the solder begins to melt, it will flow into the braid.
Do Not tarry too long.
Lift the braid up. Look to see what solder has been removed, then cut the solder soaked tip of the braid off.
Start with a fresh new tip.
Begin again. Remove as much solder as you can, from the circuit trace hole area, that the prong of the DC Power Jack is in.
Do this for all of the DC Power Jack prongs.
Now reach under the motherboard, and grab the DC Power Jack with the tips of your fingers, and thumb.
The tips of your fingers, and thumb apply pressure against the motherboard, and pull up on the DC Power Jack.
The knuckles of your first finger, second finger, and thumb, press against the motherboard. This acts as leverage.
While applying pressure start melting the solder on one of the prongs.
The prong will ease up out of the motherboard, BUT only just a little.
This is because the other prongs are holding the jack.
Now heat up a prong close to the one you started with. As the solder melts the prong will start to come out.
Keep going around on all the prongs, until one by one they start coming up out of the motherboard.
NOTE*
The MAIN thing is you DO NOT want to heat the motherboard too much, when removing the DC Power Jack.
On the motherboard are Circuit Traces. (Also known as Signal Traces)
These are the tiny, thin copper wire looking paths, on the motherboard.
TOO much heat, and you can burn the motherboard, and lift a circuit trace off of the motherboard.
TOO much heat, and you can overheat the circuit trace 'hole', and it can't be tinned again.
(Tinning = Thin coat of solder)
GO s-l-o-w. Stop OFTEN, and let everything cool down. There is no need to rush.
After the DC Power Jack is removed, there may be a thin skin of solder covering the circuit trace holes.
Don't mess with it. When the new jack is put into place, with the prongs against the thin skin of solder, touch the thin skin, and the prong will poke through.
Also after the old DC Power Jack is removed, the circuit trace hole areas need to be prepped.
An old toothbrush works best along with Isopropyl Alcohol, to clean off the residue left behind.
[CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with NO sparks or flames present ]
Sometimes you may have to carefully use a small piece of fine sandpaper.
Clean the circuit trace hole area so that it is bright, and shiny, Then tin the area.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Make SURE your solder connections are good!
Shiny bright solder joints.
A cold solder joint will have you scratching your head, wondering what could be wrong.
Practice, practice, practice, your soldering techniques, before working on the laptop.
IF, this is NOT the laptop in question, please post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Computers & Internet
Kenmore refrig with burnt up relay etc. and a melted prong. Can i fix compressor easily by replacement
If the terminal on the compressor is burnt or broken the compressor must be replaced.
Aug 23, 2011 | Microwave Ovens
Broken prong iside computer for mouse now mouse dont work how do i fix it thank you
If the prong is broken inside the computer then the best thing to do is to get a usb mouse or a wireless one. I ran into the same problem with my keyboard and purchased a usb keyboard and it works fine. Good luck!
Oct 25, 2010 | Computers & Internet
My new Dell flat screen monitor is blank and posting a message - entering power save mode- ... when I restart it briefly displays the Dell logo and other normal display at normal startup then switches to...
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Jun 07, 2009 | Dell E193FP 19" Flat Panel LCD Monitor
My lap top computer (Dell) . The hookup to the electricity is broken off . The little prong that sticks out for you to hook up to is broken off inside the computer on the mother board
This will require attention from a technician that can disassemble your notebook and replace the power connector. Contact Dell or a reputable local computer repair shop. Most likely, you will receive faster and more affordable service from the local shop.
Hope this helps.
Mar 11, 2009 | Dell Inspiron 1000 Notebook
I have a Electrolux , EL6988 Canister Vacum, howeveer the brushes and motor will not run when turned on. I have take the plates and cleaned around the brushes, but it will not come one. The vacum comes on...
Turn the brush unit upside down, so you can see the brush roller. Then, with the brush roller positioned nearest to you, you will find the reset button close to the rear edge, near the wheel that's on the right hand side as you look at it.
Good luck! I hope this works for you. I value your feedback. Please remember to rate this response.
Feb 19, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Little stand prongs on back of Dell wireless keyboard are broken
maybe..but the replacements are hard to come by..try the support.dell.com site under model and then support and accessories...
Nov 21, 2008 | Dell 0Y3740 Keyboard
Broken Prong inside connector for mouse
If the ps2 port on the main board is broken you will need to replace the board. If this is the case and your computer has usb ports on it just go out and buy a usb mouse.
If the part that is broken is from the mouse by using tweezers try to gently remove the broken part from the board. if unsuccessful use the usb port with a usb mouse.
Oct 21, 2007 | Computers & Internet
Dell Inspiron 1000 Notebook Logo
44 people viewed this question
Alun Cox
