I need to know how to install my 10" pyle sub woofer into my clarion stereo. i can not find a subwoofer out put on the stereo but the manual says it is suposed to be able take a sub woofer. How do i get it to work????
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
