Question about Roper RAX4233PQ Top Load Washer
Cold water keeps running
Will not stop at all
  • 6,784 Answers
Hi, this is a broken water inlet valve assembly. replacing this and the relay will fix this..
Posted on Mar 11, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
Cold water does not stop at set levels. Too much flow.
Blockage in pressure bottle or small hole in pressure bottle tube.
Feb 25, 2010 | Washing Machines
I have to manually turn on and off my cold water valve at the wall or it will run non stop. meaning if i forget for a little too long ill flood my house.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Feb 03, 2010 | Washing Machines
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Water temperature out of range cylce keeps stopping
its easier to go to home depot and get some pipe insulation ,,if you unplug water sensor you will stop water,,
Dec 24, 2008 | Fisher Paykel EcoSmart GWL15
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Roper RAX4233PQ Top Load Washer Logo
51 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
