Question about Whirlpool Duet GHW9150P Front Load Washer
Brand NEW Whirlpool Duet Sport
Just bought a Whirlpool Duet Sport about 2 months ago, and recently I ran a wash load and wasn't sure when, but it shut off and locked the door. (after i had already started the cycle and walked away - it never finished the cycle ) i played with it a bit and was able to turn it back on and unlock the door to get my clothes out. but today, I put clothes in, detergent, started it, walked away, and when i came back it was off. and the door is locked. i can not get my clothes out and it's time crucial. tomorrow I am going to try to contact where I bought it, but in the mean time, is there anything I can do to fix this?
  • Anonymous Mar 22, 2009
    Whirlpool Duet Sport Front Load Washer
    Washer shuts off when it goes from wash to rinse. Shows error F20. What is this?
    President:
  • 1,294 Answers
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door lock mechanism is broken or removed from door.
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Central Control Unit (CCU)
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Posted on Mar 11, 2009
  • prem mathew Mar 11, 2009
    This is for the Whirlpool Kenmore HE2 Plus, but it could be useful
    1 Unplug/Disconnect the washer
    2 Remove the lower kick panel
    3 Reach up along the inside of the front & locate the bottom of the door switch/lock unit.
    4 Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
    5 Gently pull the tab down about quarter inch or until a click is heard. Door may be opened, gently!!! Remember this is a free service, so rate me very nice, its a way/level of saying thk'u.
My whirlpool duet sport washer just stops completely mid cycle and shuts down
If it has a safety switch that shuts the washer down when the lid is open, it could be going bad. It's a simple repair.
Jun 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washing machine
F-01 is a communications error between the CCU and EEPROM. The first thing to try is unplugging the machine for 5 or 10 minutes. If that doesn't fix it, you'll need a new CCU (probably need to replace that anyway). Though if you just got it 2 days ago, call the store you bought it from - they should replace it (and help you get it open to get your clothes out).
Sep 07, 2007 | Washing Machines
Have a whirlpool duet front loading washer. Recently bought a new house, only way to access basement is up 5 steps on side of house to landing with railing.cannot turn machine on landing so door is facing...
This may or may not be helpful but please see the following Whirlpool installation and service manual for the Duet Sport washer.
It has a number of sections on accessing components and you may be able to determine how to take the front off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Following is the Whirlpool service manual for two other models of the Duet washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flases F and sud and will not drain
your using to much soap front loaders use 2 table spoons of soap and maker sure it's HE soap
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
273 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
