Question about HP LaserJet 4 plus Printer
The mIO menu item cfg network will not set to "yes". Seems to accept with enter but go on line and back to menu it has defaulted to "no"
  • dlhansen_962 Mar 16, 2009
    hp 4 has no apply button to glick, It has an enter button on the panel. Same functio. It doesn't save the setting
  • HP Master
  • 19,396 Answers
Ensure that you save settings after changing options from the menu.
If that still does not work, then try using the diagnostic software to change settings , and ensure settings are saved afterward.
Posted on Mar 16, 2009
    Sergeant:
    Champion:
  • 237 Answers
The jet direct card is not functioning properly. It will need to be replaced.
    Sergeant:
  • 320 Answers
Http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=25478&prodTypeId=18972&prodSeriesId=25478&objectID=bpj02326
the above link has all the required info regarding this just read and follow the instructions.
for  HP LaserJet 4L, 4 Plus, 4V, 4Si, and 5 series and HP Color LaserJet printers
To configure TCP/IP parameters from the control panel, use the following instructions:
  1. Press MENU, repeatedly, until one of the following messages appears on the control panel: HP LaserJet 4 and 4m printers:----AUX IO MENU
    HP LaserJet 4 Plus, 4m Plus, 4v, 4mv: ---MIO MENU
    1. Press ITEM . CFG NETWORK=NO* will appear.
    2. Press the PLUS button once. CFG NETWORK=YES* will appear.
    3. Press ENTER or SELECT .
    4. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
    5. Press the PLUS button. CFG TCP/IP=YES* will appear.
    6. Press ENTER or SELECT .
    7. Press ITEM until BOOTP=YES* appears.
    8. Press the PLUS button. BOOTP=NO will appear.
      • When using BootP or DHCP, keep the setting BOOTP=YES* .
      • The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
      • No other TCP/IP configuring is necessary.
    9. Press ENTER or SELECT .
    10. Press ITEM . IP BYTE 1 = (value) will appear.
    11. Press the PLUS button until the value of the first byte of the IP address appears on the control-panel display. By pressing SHIFT and the PLUS button, the value will decrease.
    12. Press ENTER or SELECT .
    13. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
    14. Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=), syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=), and timeout (TIMEOUT=).
    15. Press ONLINE . Print a self-test page to verify the IP settings.
    16. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
Posted on Mar 11, 2009
  • 583 Answers
After u change the settings to yes.click on apply to apply the settings permanantly. thnks
How do I reset xerox 3045
Try this:
1. To reset the NVRAM (this holds the control panel settings), turn off the printer.
2. Press and hold the On Line (0) and Enter (4) buttons, and turn on the printer. Keep the On Line (0) and Enter (4) buttons depressed until the message "Initializing...Please Wait" appears on display (this takes about one minute).
3. Release the On Line (0) and Enter (4) buttons and wait for the front panel to display "Ready." This takes about 45 seconds.
4. Press the Menu Up (1) button until the Reset Menu is displayed.
5. Press the Item Up (2) button until Factory Defaults is displayed.
6. Press the Value Up (3) button to display the choices. To actually reset the factory defaults you would select "Yes."
Aug 03, 2016 | Xerox WorkCentre 3045ni Multifunction...
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
I am unable to access my omnistack 4024c using telnet or through Hyperteminal, how i can reset the switch to its factory settings
  1. You need to connect via a console serial cable with suitable terminal software running.
  2. Power on the switch.
  3. Hit any key when prompted by boot process about 10 seconds after power-up to get to boot/diagnostic menu.
  4. Enter c
  5. Press enter (which accepts the defaults) until line displays: "Boot Flags :0xb"
  6. Enter 0x1000
  7. Press enter until back at the "[Boot]:" prompt
  8. Enter S to save settings (thats a capital S)
  9. Enter @ to boot
The switch should now be back to factory defaults.
Mar 14, 2011 | Alcatel OmniStack 4024C Networking Switch
I cannot get the printer on my network. What settings must I use with DHCP to automatically pull the IP address and be identified on the network? HP 5100 dtn
On the control panel, navigate to the Configuration menu and within it, to the EIO menu. Navigate to CFG NETWORK and select YES. Navigate to TCP/IP and select ON. Navigate to CFG TCP/IP and select YES. Navigate to BOOTP and select NO. Navigate to DHCP and if you want automatic IP addressing, select YES. If you select NO for DHCP, you will be able to manually set the TCP/IP parameters, including IP address, subnet mask and default gateway.
Nov 05, 2010 | HP LaserJet 5100dtn Printer
HOW DO I CHANGE THE IP ADDRESS ON THE HP4300TN PRINTER
Type the present IP address into your browser.
Hit enter.
Click the NETWORKING tab.
Make sure MANUAL is set under CONFIGURATION METHOD.
Type in your changes. You will loose your connection to the browser at this point.
The other way is to go thru the MENU on the printer until you reach EIO X JetDirect Menu.
Hit ITEM-> once, Hit VALUE+ to get a YES. Hit select. Click ITEM-> until you reach CFG TCP/IP=NO
Hit VALUE+, Hit SELECT. Hit ITEM-> until you get to the IP BYTE 1=XXX.
Hitting VALUE+ or - will change the number, SELECT will lock it in.
From there use ITEM to get to the 2, 3 and 4 octet.
Sep 17, 2010 | HP LaserJet 4300tn Printer
How do i configure ip address for my HP printer
It is in the MIO section.
Answer yes to CFG?
Dec 14, 2009 | HP LaserJet P4015N Printer
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
May 26, 2009 | HP LaserJet 4100dtn Printer
I would like to network our HP color laserjet printer through our Telus wireless router. I connected the printer with a network cable, to the router, but when I tried to install the printer through my...
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Dec 04, 2008 | HP Office Equipment & Supplies
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
HP LaserJet 4 plus Printer Logo
140 people viewed this question
Ben Johnson
