Question about Epson Stylus C84 InkJet Printer
Put paper in epson c84 for printing. - Epson Stylus C84 InkJet Printer
  • Cathy Pearson May 11, 2010
    I have a epson stylus 84 printer
    It is working by letting the paper through but can't print  in black or only one blue color. My project is brownish and it won't print that.
    New cartriges.
    Thank you
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi there - you haven't said what your problem is. What is it?
  • 353 Answers
This seems to be a none-problem, of no interest now to the original poster. I think we may call it "solved".
Posted on Mar 31, 2009
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Someone please help me!
Hi Emma,
It sounds like your PC is printing to draft everytime, have you checked your printer settings within Control Panel, Printers? If nothing stands out to you then probably best thing to do is a reinstall of the printer driver, 99% of the time this will sort it.
If this has helped you then please rate me!
Aug 26, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Hi
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Paper jam epson c84
If you are sure that no scraps of paper (or other object) is jamming the paper feed path, you will need to dismantle the printer to investigate further. This is really a job for a technician; however, if you want to have a try yourself, you can download the service manual from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Also, post a new comment to this effect since I can provide useful extra info on getting these difficult machines apart.
May 08, 2009 | Epson Stylus C84 InkJet Printer
Epson C84 paper light is on and power light is flashing what can I do?. E Green.
Please check if there are any foreign objects inside the printer. And unplug it from the computer and test if you can print just using the printer itself without using the computer.
Make sure there is paper loaded on the printer and the printer is OFF.
Hold down the paper button and press and release the power on switch, if you can see flashing green light release the paper button. Just wait till it feeds on paper. If it feeds on paper and prited on a pattern it means the printer is working fine, but if not you have to call your manufacturer of your printer.
Feb 28, 2009 | Epson Stylus C84 InkJet Printer
Not printing
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Feb 21, 2009 | Epson Stylus C84 InkJet Printer
Epson stylus c84 inkjet printer
I don't know if this will help but your problem sounds like one I had with a C82 model. On the right side of the printer below where the print head rests is a small plastic suction tube. This tube can become disconnected and will prevent the printer from printing. Check to see if this is your problem. In the picture the red circle shows where the tube connects and the yellow shows the tube.
Jul 13, 2008 | Epson Stylus C84 InkJet Printer
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
