Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Oil seal for rear tine shaft
Can't find serial number on tiller that has a 6hp motor and is about 30 years old and need a oil seal on the rear tine counter shaft. I also can't find a serial or model number.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    the tiller model # and serial # tags are generally located on the tine housing.
  • John McKinney May 11, 2010
    If you can get me the all of the numbers you can find on the engine, I will be able to get you a parts diagram for your tillers engine. thank you.
  • 23 Answers
I checked my troy bilt and can not find any numbers above the wheel on the housing and I know they have not been taken off. Is there anywhere else to look?
Posted on Jul 04, 2010
  • 389 Answers
Tine shaft seal is part number 9618
also MTD P/N GW-9618099/GW-9618
Sometimes if you can get it out without destroying it, you can find a manufacturers number on it also and purchase it from a local bearing supplier or take it to them and they can measure and match it for you
Posted on Oct 02, 2009
  • 26 Answers
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Posted on Sep 14, 2009
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
Mar 04, 2011 | Troy-Bilt Pony Garden Tiller
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Apr 20, 2010 | Mtd Products Yard Machines 158CC Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Leaks oil around the tines.
 an new oil seal needs to be put onto the output shaft of the transmission.  remove the plug wire if you attempt to pry out the old seal and tap in the new seal.  Be careful not to damage the case and grease the seal and shaft when you replace the oil seal
Mar 29, 2009 | Troy-Bilt Garden
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
453 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
