Apple iMac, 24-inch, 2.8GHz  Mac Desktop
Problem for Apple iMac, 24-inch, 2.8GHz Mac Desktop
Imac24 computer- won't boot up-
By musicman1429 on Mar 11, 2009
imac24 computer- won't boot up-
small clicking sound from dvd when power button is pressed. - found power supply bad- 1 transistor visibly burned up- changed power supply- good to go..
Comments:
Mar 13, 2009
- Yes the computer started right up & is running with no issues-- as an added test there appears to be voltage display mini leds, (green) on the bottom center of the motherboard. (visible thru the bottom vent screen by the memory chip cover). looks like 3 light up when power is correct, I only had one light before changing the power supply.
Mar 15, 2009
- Here's a few suggestions: There appears to be a couple different power supplys in the imac 24's - my suspect model had 2 large aluminum heat sinks on the bottom & sticking out the side. The burned part was visible immidiatly on top of the board (surface mount transistor), examine the power supply components for damage, including any capacitors. A swelled silver top indicates a failed cap from overheat and will need replaced. Likewise I have repaired many motherboards with the swelled capacitor problem. Using a voltmeter, check for presence of +5, +12, +3.3 volts coming out of the power supply to the motherboard and/ or to the hard drive when the computer is turned on. I think there is an addtional +24v to the display.
http://en.wikipedia.org/wiki/Serial_ATA for power pinouts to the sata drive. Also a bad component may rob power- a non-running fan could be shorted, try unplugging anything that doesn't start--hard drive power- dvd power- fans- or display- (to test without the display listen to see if the hard drive spins up)
Solution #1
posted on Mar 13, 2009
Not Rated)
cheap to fix
Rank: Wiz
Rating: 81%, 262 votes
so is it fine now?
Comments:
Mar 13, 2009
- my problem is I have 3 lights but the top light is off, I cant remember what lights i had before but the last hing i know is that the apple was gone to sleep mode since then it just powers on with fans and nothing else happens, hard disk doesnt spin, no dvd spin
I am afraid to get a power supply and its same problem. what do you think?
Was this helpful?
Yes
No
Popular Solutions for Apple iMac, 24-inch, 2.8GHz
Questions and Unsolved Problems for Apple iMac, 24-inch, 2.8GHz
Do you recommend Apple iMac, 24-inch, 2.8GHz Mac Desktop?
Answer
Answer
I would like to know how to reset the password on my laptop? how do I do that?
Answer
i have a laptop toshiba satellite a85-s107..got blue screen of death
Answer
i have a toshiba satellite laptop a85-s107....got blue screen of death
Answer
have a toshiba satellite a85-s107..blue screen of death
Answer
have a toshiba satellite a85-s107....got blue screen
Describe your Mac Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Mac Desktop Experts
Top Computer & Laptop Repairmen
in Windham, ME
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
