Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
  • 4 more comments
  • bluesteel528 Mar 15, 2009
    thank you, but how do i know if the gauge (dial) it self is bad and just wont register or if the entire pressure gauge unit is bad and need replaced or do you just replace the entire unit ...
    by the way it is direct drive and model number is 921-153-101
    how do i know if its the pressure gauge or the regulator that is bad ? the gauge wont register any pressure readings at all when i am using the compressor, but my nail gun works fine , if anything it shoots a little to hard.
  • Dominic
    Dominic May 11, 2010
    Moreover, if your compressor has an Air Intake Filter, it
    should be cleaned on a weekly basis (assuming you are using
    the compressor about 3 days a week). When the filter starts
    to develop debris that is becoming harder to clean out, or
    you notice any tears or holes in the filter, the filter
    should be replaced.
  • Dominic
    In a rotary screw compressor, oil should be
    changed about every 7000-8000 hours. This depends on the
    type of compressor you purchase. For a Reciprocating air
    compressor, generally you would change the oil approximately
    every 3 months. For a more accurate time frame, I'd need your model number to find the recommended schedule for your
    compressor.
  • Dominic
    So, you're using an oil based horizontal tank unit ; Belt Driven? Horse Power? Max PSI? If you have the model I can pull up the spec sheet.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Posted on Mar 11, 2009
Both Gauges stay at same pressure when trying to adjust outlet pressure to tools
it seems like you might be adjusting a valve before the regulator. the outlet pressure from the compressor vessel should remain celatively constant. if you are adjusting the pressure whilst using the airtool and when you stop the regulator gauges return to/or close to/ the 150 PSI then this also points to you not adjusting the regulator.
Some compressors have 2 outlets... one regulated and the other not.
Feb 11, 2018 | Craftsman 15 gal Air Compressor 3 hp UMC...
Regulator Problem. Both Gauges stay at same pressure when trying to adjust the outlet pressure for tool settings
It sounds like a contaminated regulator, possibly due to moisture if you have never drained the tank. If it is a cheap air compressor then the best course of action would be to install another regulator as it is not worth the time to try to rebuild the regulator as most likely it is not a quality part. I would look into Wilkerson or Speedair brand parts to fix your issue.
Nov 14, 2013 | Craftsman 15 gal Air Compressor 3 hp UMC...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The compresor is not building up the pressure, it only reaches like 15 PSI .. and is not the drain valve
check the regulator valve. the black cap must be pulled out slightly to allow it to turn. adjust that while watching gauge for change. there is also another pressure release near the pump be sure it is seated fully.
Jan 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a Sears evolv 3 gal air compressor that will not inflate a auto tire, even a partially de-flated tire. I let the pressure build to 100 psi and checked all fittings. Still wil not do it. Compressor...
The evolv air compressor was primarily designed to power a very small nailer. The pressure regulator (knob in front) should be turned clockwise till it stops to attain full pressure. At this setting it should air your tire. If not you may have a defective regulator. There is a trick to get full pressure from your tank. Notice the small pressure safety valve on the side of the unit. You could remove this valve and install a fitting giving you two ports. One for the safety and other for a quick disconnect. This second port will give you access to tank pressure without going thru the pressure regulator. This mod is safe because you still have access to regulated pressure when you need it. Good luck
Jul 07, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 Gal. Air Compressor 1 HP Hortiz
Does it run? Does it stop running? Does the pressure gauge read anything at all? Is there a regulator on it? Can you take the reg off? A bunch of things to check, get it running and let me know what you find, and I will try to tell you what's next.
Feb 27, 2010 | Craftsman Air Tools & Compressors
Compressor won't build psi above 30,is this typical of the regulator or pump? the compressor is a 3 gal craftman about 1 yr old.
sounds like the regulator is faulty, normal running air should reach 110 psi, this will allow you to run tools...
Jan 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Will only produec 20lb of pressure
I have the same make/model. Connect a device to your air line (impact, blow gun, doesn't matter anything that will use air). Operate the device and note if the pressure on your output gauge falls, and then rises back to 20# when you let off of the device. If it does, this indicates that your regulator is either defective, or it is adjusted too low. Try adjusting the regulator knob, operating it in both directions, and note the pressure on the output gauge. If you can get it to rise, you're home free!
Regards, --W/D--
Jul 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
729 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
