Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice makers not making ice and water tubing is
Ice maker not making ice and water tubing is frozen again
  • drz860 Mar 15, 2009
    Icemaker is working, but no water from water dispenser.GE Profile sidebyside PSS25n Refridgerator
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check water valve or switch
Posted on Apr 02, 2009
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
Mar 03, 2017 | Refrigerators
I had the power out on my refrig for about 8 hours. Now the ice maker has stopped making ice. Water in the door works, but no water going to the ice maker and not dropping ice. Do I need to defrost the...
There is a dual acting water valve that feeds the ice maker and door water seperately.
If your power went out - chances are good the solenoid on the icemaker side of the valve has failed - so it will not open the valve on the demand of the icemaker timer.
To find out - you will need to check that there is voltage at the valve.
With a model #, I can help you better.
Thanks!!
Feb 20, 2010 | Refrigerators
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
 You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
Aug 31, 2009 | Maytag Freezers
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
ICE MAKER
You can fill the tray with water from the tap and turn arm on. After doing this the ice maker should drop the ice that you made by poring water in the tray.This should tell the water solinoid to send water again to the ice maker.
This should solve the problem for a long time until it slowly tries to freeze the feed tube shut again. Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
Again, this assumes nothing is actually broken.
This worked for me. Good luck.
Jan 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
NO WATER DISPENSING FOR ICE
did you clear out the fill tube in the freezer section that lets the water enter the ice maker, it could be frozen
it the line and the tube are clear then replace the water valve
May 11, 2008 | Kenmore 26.0 cu. ft. Side-By-Side...
Ice maker doesn't work
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Oct 07, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
