Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Replace Color Wheel
I have a high pitched whine from the rear of a Samsung HLN 5065W TV. I think it is the color wheel bearing failing. Is this so and if so how do I repair it.
  • aljrh Mar 13, 2009
    I have sound but no picture and also have a high pitched whining noise coming from the rear.  The noise cycles for about ten seconds then stops,  then does it again.  All three lights on the front panel blink and the TV will shut itself off.
    According to owners manual,  three light blinking means the bulb is bad,  so I replaced bulb today,  was not the bulb.  still have same problem.
  • 20 Answers
If the problem is the colour wheel there is a slight delay when first turned on.If the colour wheel is at fault it is located right adjacent to the lamp it is pretty easy to change with 2 screws holding it in place.they are about 100 to 150
Posted on Mar 11, 2009
MY SAMSUNG HLN 507 WX/XAA T.V. IS MAKING A WHINING SOUND WHEN I TURN IT ON
Your color wheel is going bad, when it fails the TV colors will be way off and it will shut down. They range from $50 -$125 . Here is one for $98 for your tv. http://www.amazon.com/Projector-Replacement-Samsung-HLN507WX-HLN567/dp/B00HJOLQ7G
Jan 09, 2015 | Samsung Televison & Video
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
I have a humming noise coming from my 5 year old samsung 50 inch dlp tv , I have replaced the lamp 6 months ago so what else couyld the noise be coming from? I have a great picture and color.
If it is a high pitched whine it is most likely the color wheel; the bearings in the wheel go bad and if you google the model number with color wheel you will find it.
The whine is the early stages of the wheel failing; when it goes out you will either have shutdown or a grinding sound.
Let me know if you have questions as I am here to help.
SD TECH
Aug 09, 2010 | Samsung Televison & Video
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Samsung HLN467WX projection TV whines.
The color wheel is the most likliest cause of that. Replace the color wheel.
Apr 01, 2010 | Televison & Video
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
HL-R6768W not turning on. High pitch spin sound. Bad color wheel?
The high-pitched whine is definitely the color wheel.  The early color wheels had problems and many had to be replaced.  As part of the turn-on process, the TV checks for light and then checks for color wheel sync.  If the bearings are wearing out/dried out, it could cause issues with getting the proper color wheel sync, causing the set to not pass the turn on sequence.
Check Sears or partstore.com for a color wheel.  I like sears for experimental replacements since they allow easy returns.
BTW, mine is an early 61".  My color wheel was replaced when I had to replace my Light Engine.  My in-laws 50" was an early one and theirs went out within 2 years.
Jan 06, 2009 | Samsung HLN5065W 50" Rear Projection...
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
208 people viewed this question
Jerry Greenberg
Jerry Greenberg
