Question about Dell OptiPlex GX270 PC Desktop
Dell GX270 does not recognise HDD after CMOS battery failure
I have a Dell GX270. My machine has been in storage for about a year and a half and when I first started it, it behaved okay, brought up Windows XP as expected, but reported a low internal battery voltage when it was going through BIOS POST checks. Didn't think much of it until I switched it on the next day and Zip, Nada, didn't even get past POST checks. Checked BIOS settings via F2 at startup and it didn't even have a HDD recognised, IDE HDD set to OFF in BIOS setup. Checked the HDD in another machine and it works fine. Replaced the CMOS battery a CR2032 and still no change. Tried a different HDD in the GX270 and still nothing. Even with new battery in I reset the CMOS memory and still doesn't recognise the original HDD, so I am completely stuck! Anyone know of a cure for this?
  • widget100 Mar 11, 2009
    Unfortunately its the BIOS that sets this field after it has identified the model of HDD in the computer during startup, I don't get to set this field. If I reset the field to Auto, it simply comes back with a drive type as "Unidentified Drive" which is its nice way of saying 'there is no drive!'. Thanks for your help though.
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Posted on May 09, 2015
  • 124 Answers
It Seems to me IDE HDD In your BIOS should be set to on.
Posted on Mar 11, 2009
  • Mark Van Skiver Mar 11, 2009
    OH. Thought it was to simple.
    OK try this remove power from computer.
    Open computer up.
    Unplug power from HDD. Not IDE cable.
    Follow power cable to power supply, find a different power line one hopefully on different line.
    Plug new line into HDD.
    Plug computer back in.
    Try reboot.
    I hope it is a simple power supply failure. But watch for led's on HDD & CD/DVD drive to see if they are working. No light no workie.
    Also Is your Cd/DVD drive opening & closeing. If it is that is a good power line. Borrow it if above does not work. Just leave CD/DVD unplugged for diagnostic.
    Good Luck.
Have you tried a System Restore/Recovery? Can you boot in safe Mode? Have you removed and tested the HDD? Do you have a Windows Repair Disk? How old is the Machine? May be time to replace the HDD? Has the Machine been losing time when you restart after a long shut down? Try replacing the CMOS battery. NTFS:
Mar 20, 2013 | Dell Optiplex GX270
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
When booting my dell optiplex GX270 desktop,"alert! system battery low pops out, press F1 to continue or F2 for setup utility" and the screen colour chances. please, what do i do?
i think this is the problem about your cmos battery so first you change your cmos battery contained in your lap is attached with your laptop motherboard.
Sep 03, 2011 | Dell OptiPlex GX270 PC Desktop
I own a Dell Optiplex GX270 Hi I get a message coming up saying ``Alert battery low voltage press F1 to continue'' on a black screen What should I do and how thanks
I think this is reffering to your cmos battery, switch off the machine and remove the side cover, have a look around for a flat cell battery, it is usually a cr2032 or similar, these batteries are cheap to buy (maybe £3 or so)the battery in question, if your not familiar with cell batteries, looks something like an oversized watch battery, maybe 20mm in diameter.
May 05, 2011 | Dell OptiPlex GX270 PC Desktop
I am trying to upgrade to a 1tb SATA HDD on my Dell Optiplex GX270. It does not recognise my new drive in my BIOS, I have updated BIOS to A07. Am I missing something? Is it compatable with SATA?
I have the same model PC with a 250gig Sata HDD and dont have any problems. If a PC can read 250g it should be able to read 1000g. This may sound silly but is Sata turned on in Bios
Mar 25, 2011 | Dell OptiPlex™ GX270 PC Desktop
Where can I buy a new battery for Dell Optiplex GX270? (I brought it second hand from my last employer. At the front it says Optiplex GX270 it does look like a other ones on ebay, but the sticker on the...
I am guessing you mean the motherboard CMOS battery.
Here is one place
Replacing the battery
Feb 14, 2011 | Dell OptiPlex GX270 PC Desktop
OptiPlex GX270 PC Desktop: The previous tech who worked on this machine someh...
Open the chassis info here:
HDD here
or here
May 17, 2010 | Dell OptiPlex GX270 PC Desktop
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Nov 17, 2008 | Dell OptiPlex GX270 PC Desktop
Disk seek failure
check system CMOS to see if hdd is recognised on cmos, if yes check boot order that hdd is first boot device, if yes, check op' system still intact on hdd. If no to all, check ribbon cable/and/or power supply plug to hdd, report back...
Sep 15, 2008 | Computers & Internet
Dell OptiPlex GX270 PC Desktop Logo
1,113 people viewed this question
Alun Cox
