Question about GE Profile WPRE6100G Top Load Washer
Motor makes a clunking sound (Shuts on/off)during agitation cycle
For a minute or so during the agitation cycle, and then again later on, the motor makes a clunking sound (from other things I've read, I believe this is due to the motor rapidly shutting on & off). How can I determine if the problem is with the motor, the lid switch (magnetic) or an electronic issue with changing motor speeds? Aside from this issue, the machine operates normally. The washer is almost 7 years old. Thanks in advance. Steve
    Genius:
  • 1,066 Answers
Sounds like you need a new motor/transmission coupling.
Posted on Mar 11, 2009
    New Friend:
    Problem Solver:
The problem is the springs. Fixed mine for $48 with the kit. New springs are much stiffer and won't let the drum go crazy, Could never get past any spin cycle at any speed and now all is fine.
Posted on Dec 03, 2014
    Scholar:
  • 124 Answers
Not sure what clunking sounds like.
Your motor may not be shutting on & off It may be trying to start. Most motors Have a start capacitor & a run capacitor to help them turn. They do exactly what they sound like Start cap kicks motor to get it going. Which is more than likely whats wrong with yours. The run cap keeps it spinning by kicking it every revolution.
Now some start caps & run caps are built together, Others are separate the start cap is usually paper filled & the run cap is oil filled (help keep it cool).
*** Both capacitors store electrical energy (voltage amps) even when machine is unplugged they are very DANGEROUS & can harm & even kill you.
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer fills,but when it tries to go into agitation cycle
if its not agitating on any cycle the you transmisson has went out ,,,,, if it does in some cycles but not others you have a bad timer
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
When starting, hear a noise like if the motor has problem rolling. The dryer works but stops during the cycle. Smeling heating after a while. And few minutes later, restarts and works, and stops...
sounds like your motor is on the way out. Hard to start-- when it does go it eventually overheats---- wont restart till cools down. sounds like a motor going bad
Mar 07, 2008 | Dryers
GE Profile WPRE6100G Top Load Washer Logo
342 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
